Possible to route separate Serial to Ethernet Ports?
I have a 2611XM and have 2 Serial T1 interfaces, each with a T1 line connected. Is it possible to route each T1 line to a separate Ethernet port within the router.
So Serial 0/0 traffic only routes to Ethernet 0/0 and Serial 0/1 traffic only routes to Ethernet 0/1.
Currently the T1 lines are multilink together.
Re: Possible to route separate Serial to Ethernet Ports?
Yes you can use PBR Policy Based Routing, if you can tell us more about your scenario we can help you out more (especially the multilink part):
Policy-Based Routing
http://www.cisco.com/warp/public/732/Tech/plicy_wp.htm
Configuring Policy-Based Routing
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fqos_c/fqcprt1/qcfpbr.htm
HTH,
Mohammed Mahmoud.
Thanks for the reply. I am using 1 of the Ethernet ports for my internal network. The other is used for a live video conferencing system. When the video conference is connected and any type of heavy network activity, downloads, uploads, it interrupts the video conference. I want to separate them to each use a separate T1. This will hopefully avoid the interruptions.
This is my current configuration... i have xxx the ip addresses for privacy.
Current configuration : 1925 bytes
version 12.3
service password-encryption
hostname myhostname1
boot-start-marker
boot-end-marker
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
no ip source-route
ip cef
ip name-server xxx.xxx.xxx.xxx
no ftp-server write-enable
class-map match-all myhostname1-class
match access-group 199
policy-map 2-class-short-pipe-egress-myhostname1
class myhostname1-class
priority 640
class class-default
fair-queue
interface Multilink3
description Multilink PPP
ip address xxx.xxx.xxx.xxx 255.255.255.252
service-policy output 2-class-short-pipe-egress-myhostname1
ppp multilink
ppp multilink group 3
interface FastEthernet0/0
ip address xxx.xxx.xxx.xxx 255.255.255.224
duplex auto
speed auto
interface Serial0/0
description T1-1
encapsulation ppp
load-interval 30
no fair-queue
ppp multilink
interface FastEthernet0/1
speed 100
full-duplex
interface Serial0/1
description T1-2
encapsulation ppp
load-interval 30
no fair-queue
ppp multilink
ip classless
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx
no ip http server
end
Super Bronze
Although not related to your initial question about dedicating specific T-1s to specific Ethernet port, you note the underlying issue is video conferencing is being disturbed by other traffic. This is something that QoS should be able to handle. Admittedly, dedicating a link for your vidconf should avoid the issue, it also precludes that bandwidth from your other apps when vidconf isn't using it. You might want to look deeper into your QoS operation and see if it's behaving as it's expected.
I see you have a two class policy that has both LLQ and a default FQ. I see the class map uses ACL 199 but that's not shown in the config? Have you seen all vidconf traffic being placed in the LLQ? What about the far side router?
I am not too concerned about precluding the bandwidth. I do have access lists. QoS seemed to be functioning, but still had interruptions.
Is this what policy based routing would look like:
ip route-cache policy
ip policy route-map FaEtoSerial
speed 100
full-duplex
interface Serial0/1
description T1-2
encapsulation ppp
ip policy route-map SerialtoFaE
load-interval 30
no fair-queue
ip classless
no ip http server
route-map FaEtoSerial permit 10
set interface Serial0/1
route-map SerialtoFaE permit 10
set interface FastEthernet0/1
Super Bronze
If the QoS is placing all your video traffic in a CBWFQ LLQ and there are no drops, on both sides, I'm surprised.
One issue I bumped into was this one:
http://www.cisco.com/en/US/tech/tk39/tk824/technologies_tech_note09186a00800fbafc.shtml#topic8
hardware FIFO buffer, and ATM. Don't think it applies for your multilink, but you could try a minimal tx-ring-limit and see if there's any difference in behavior.
PS:
The PBR pros can confirm, think you have something that should work after you split the multilink. However, don't forget the other Ethernet/serial, needs to be isolated from the first pair. Also, to quote Cisco "Note The ip route-cache policy command is strictly for fast-switched PBR and, therefore, not required for CEF-switched PBR."
Another alternative to PBR is to utilize VRF lite. In many cases this can be easier to configure and troubleshoot. You would create a vrf and put one of the serial ports and one of the ethernet ports into the vrf. this would maintain seperate routing tables for each pair of interfaces.
bjw Silver
Silver
I bet if you did a little research related to policy based routing you could find something that works.
http://www.cisco.com/en/US/customer/tech/tk364/technologies_configuration_example09186a0080211f5c.shtml
Hall of Fame Super Silver
Joey
If the serial lines are multilinked then it is not possible to route data from them separately. If the serial lines are separated and each is treated independently then it should be possible to route them separately.
There are a couple of options to consider which might achieve what you want. You could configure Policy Based Routing. In policy based routing you can make decisions about how to route based on where traffic comes from or other criteria rather than route just on the basis of how to get to the destination address.
The second alternative to consider would be to configure vrf lite. With vrf lite you are logically separating the box into several logical parts. With vrf lite you can link one serial with its Ethernet and link the other serial with its Ethernet.
Rick
179
