Community Member
Power Cable for 1300 WAC power supply for Cat 4500E series switches
I am ordering a new Catalyst 4506 E series switch and I am using 1300W power supply.
PWR-C45-1300ACV Catalyst 4500 1300W AC Power Supply (Data and PoE)
Earlier I used to order CAB-7513AC= power cable for this power suply using dynamic configuration tool also the cisco document says this is the power cable for this power supply.
But I couldn't find this cable option in dynamic configuration tool yesterday. It gave me other options and I am not sure which power cable I should pick for 1300 WAC power supply.
Does anybody has ordered the power cable for 1300 WAC power supply for Cat 4506E switch recentlty.
Please let me know which is the correct power cable.
1 REPLY
Bronze
Re: Power Cable for 1300 WAC power supply for Cat 4500E series s
Hi Vijay,
As per Cisco u can use the following cable with product code PWR-C45-1300ACV cable..
Please check the following link for more information...
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/product_data_sheet09186a00801f3dd9.html
Pls. rate if this helps...
BR
*aijaz*
188
