Power Controller reports power Imax error detected
ernest617
My 3560 switch w/ IOS 12.2(35)SE have below message last night. Would anyone know what happen?
Sep 23 18:54:58.468 UTC: %ILPOWER-7-DETECT: Interface Fa0/10: Power Device dete
ted: IEEE PD
Sep 23 18:54:58.468 UTC: %ILPOWER-5-INVALID_IEEE_CLASS: Interface Fa0/10: has d
tected invalid IEEE class: 7 device. Power denied
Sep 23 18:57:37.542 UTC: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error,
Interface Fa0/12: Power Controller reports power Imax error detected
Sep 23 18:57:44.580 UTC: %SWITCH_QOS_TB-5-TRUST_DEVICE_LOST: cisco-phone no lon
er detected on port Fa0/12, port set to untrusted.
Sep 23 18:57:48.674 UTC: %ILPOWER-7-DETECT: Interface Fa0/12: Power Device deteted: Cisco PD
Sep 23 18:57:48.741 UTC: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Fa0/12: Power Controller reports power Tstart error detected
Thanks and Regards
Ernest
32 Replies 32
Prashanth Krishnappa
I am suspecting this has to do something with the IP phone on this port since it is requesting invalid class power. Did the phone come back up fine? If not, you might want to see if the same phone works on a different port or a switch to see if you just have a bad phone
We have a 2960 at one of our sites and we got notifications that all phones became unregistered.  I looked at the logs and saw
Sep 21 22:25:12.970 GMT: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Fa0/8: Power Controller reports power Imax error detected
Sep 21 22:25:13.675 GMT: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Fa0/15: Power Controller reports power Imax error detected
this appears to be affecting all our ports on that switch
This error indicates that PD is drawing over-current more than allowed/supported per IEEE 802.3af standard.
Log:
  • What type of the device are connected to interfaces where you are seeing this error?
  • Do you use any kind of POE splitter on the interface?
This issue is looks like it is matching with known bug CSCsw18530
CSCsw18530 - Power Imax / Tstart errors may be reported with some third party PDs
Symptoms:
%ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Power Controller reports power Imax error detected
%ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/35: Power Controller reports power Tstart error detected
Conditions:
Seen with some of the 3750,3750G,3750-E,3560-E, 3750-X, 3560-X, 3560-C, 2960S, 2960,2960C switches
Workaround:
Longer cable (>50ft) seems to fix the issue in most cases.
Solution
This issue is fixed in 12.2(55)SE3 , 12.2(58)SE1 and later releases. The following  interface configuration commands have to be applied to resolve the issue,
Switch(config)# int x/y
Switch(config-if)# power inline port 2x-mode
Switch(config-if)# shut
Switch(config-if)# no shut
The fix is present in the following platforms only :
3750-E, 3560-E, 3750-X, 3560-X, 3560-C, 2960S, 2960,2960C. The other platforms do not support 2X power mode and the workaround would be to use a longer cable.
Aru
*** Please rate if the post is useful ***
Regards, Aru *** Please rate if the post useful ***
Both ports had 7942 phones connected.  The switch is using IOS 12.2(58)SE2.  The ports are all in an up/up state now.  If the issue reoccurs I will try your suggestions.  On the same switch we do have two Meraki MR16 PoE WAP's connected also.  Is it possible they could be drawing too much power?  We'll keep monitoring.
Hi Danny,
Please make sure that those two Meraki MR16 PoE WAP's are complaint to to 8023af standard. If this meets this standard, it will work without any trouble,
If you see any abnormal behavior on PoW, use the show inline power and show inline power detail privileged EXEC commands to compare the number of connected powered devices against the switch power budget (available PoE). Verify that switch power budget can power the device.
Note:
If the switch power budget is depleted, additional powered devices will not power-on when connected to a PoE port. CDP (Cisco Discovery Protocol) helps identify Cisco devices and correctly establish the switch power budget.
Refer:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/troubleshooting/g_power_over_ethernet.html#wp1018190
Aru
This issue is solved in 12.2(55)SE3 for 3560-X and working well.
and i upgraded IOS c3560-ipbasek9-mz.122-55.SE3.bin but the command #power inline port 2x-mode not available in IOS.
Look forward for someone response to resolve this issue
Thank you all.
I'd recommend using 12.(55)SE10 instead.
after upgraded to 12.(55)SE10 still the command #power inline port 2x-mode not available.
waiting your replay
any update
waiting any Engineer replay
Yes, looks like you are hitting this bug (CSCsw18530) and why this IMAX power error popup on Cisco switch:
After a PD (connected to one of our ports) is turned on, the hardware keeps on monitoring the current drawn by the PD so if the current drawn by a PD exceeds the pre-configured cutoff current (ICUT) for a limited time (TCUT) then the power controller will shut it down and informs the software about the fault. The software upon hearing about this fault, will print out the "IMAX error" message, remove the power and start a timer to start detecting the PD after the expiry of that timer. So if the device is continuously misbehaving (i.e. drawing more than ICUT current even after TCUT time) then we will keep on powering it up and then shutting it down.
Please try to connect longer cable (<50) and let me know if it's fix this issue or not.
Sweta
I just wanted to note that I was having the same issue with the "power Imax error" and I initially attempted the config for power inline port 2x-mode:
Initially this did not work for my by simply issuing a shut, no shut comand.  However once I configured the interfaces with the "power inline 2x-mode", and then reloaded the entire switch/stack, all PDs powered up correctly and I had no errors.
It's worth a shot to attempt a full reload rather than shutting off the interface and bringing it back up.
It worked for me as my IP Clocks were taking 15.4W on Cisco C2960-8PC-L switch.
Thankyou sir.
boucherandre
We are at the begining of a wireless deployment in an hospital here, and at this  time I have 2 Aruba AP105 that stop working this week with this error log:
%ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/19: Power Controller reports power Imax error detected
I try the workaround and the solution with the  "power inline port 2x-mode" command on a  2960s POE+ 12.2 55(se5), but still the same problem.  I also upgrade the firmware of the wireless controllers to the latest.
Someone can help?
thanks!
Try this ...
1.  Command:  test cable tdr int G1/0/19;
2.  Wait for 5 to 7 seconds;
3.  Command:  sh cable tdr int G1/0/19; and
4.  Post the output to #3.
