10-16-2013 07:40 PM - edited 03-07-2019 04:04 PM
Hi, there are 3 7.5Kw power supply in my Nexus 7010.
and the redundant mode is REDUNDANT.
So what is the exactly power should I provide for this Nexus in my rack.
7.5 x 3 = 22.5 Kw ?
Thanks a lot!
10-16-2013 07:53 PM
That is correct. 22.5 is the max based on how many blades and sups you have in the chassis. Each power supply comes with 2 outputs. For load sharing, it is good idea if you can connect each output to a different PDU. You need c19/c20 power cords to connect the PSUs to the PDUs.
10-16-2013 09:48 PM
I need to correct Reza here. With current mode of redundancy you will get 11,250W:
Redundant mode means
As per table 5 in the link below 3 PS will give 11.250 in this mode:
Niko
10-16-2013 10:47 PM
Hi, thanks so much!
So, 3 PS will give me 11,250 W in this mode, which is the output.
How about the input, Should I prepare 7.5 x 3 = 22.5Kw for this Nexus ?
