Community Member
power supplt alert on isco IOS Software, Catalyst 4000 L3 Switch S
Mar 29 22:54:42: %C4K_IOSMODPORTMAN-4-POWERSUPPLYBAD: Power supply 1 has failed or been turned off
Mar 29 22:54:42: %C4K_IOSMODPORTMAN-4-POWERSUPPLYFANBAD: Fan of power supply 1 has failed
Mar 29 22:54:42: %C4K_IOSMODPORTMAN-4-INLINEPOWERSUPPLYBAD: Inline power from power supply 1 has failed or been turned off
sh log shows above
1 ACCEPTED SOLUTION
Purple
Re: power supplt alert on isco IOS Software, Catalyst 4000 L3 Sw
It is what it says , have someone check the power and see if its turned off , if not then the PS is bad ..
1 REPLY
Purple
184
