Community Member
Power Supply problem
Hi Netpro,
i am using Cat4506, recently i just replaced a new module (POE), but i noticed some power inline issue. i suspect is the power supply issue.
the error message as below,
Watts Used of System Power (12V)
Mod Model currently out of reset in reset
1 WS-X4013+ 110 110 110
3 WS-X4248-RJ45V 65 65 25
5 WS-X4248-RJ45V 65 65 25
6 WS-X4248-RJ45V 65 65 25
-- Fan Tray 50 -- --
Total 355 305 185
Watts used of Chassis Inline Power (-50V)
Inline Power Admin Inline Power Oper
Mod Model PS Device PS Device Efficiency
1 WS-X4013+ - - - - -
3 WS-X4248-RJ45V 300 267 85 75 89
5 WS-X4248-RJ45V 87 77 22 20 89
6 WS-X4248-RJ45V 250 223 51 45 89
Total 637 567 158 140
log file :
Jun 5 09:41:52.447: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: PimEthAutoNeg: S2w Read/Write Error for port Fa5/3.
Jun 5 09:46:52.519: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: (Suppressed 2 times)PimEthAutoNeg: S2w Read/Write Error for port Fa5/18.
Jun 5 09:51:52.518: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: PimEthAutoNeg: S2w Read/Write Error for port Fa5/28.
Jun 5 09:56:52.694: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: PimEthAutoNeg: S2w Read/Write Error for port Fa5/28.
Jun 5 10:01:52.761: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: PimEthAutoNeg: S2w Read/Write Error for port Fa5/28.
Jun 5 10:06:52.816: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: PimEthAutoNeg: S2w Read/Write Error for port Fa5/28.
Jun 5 10:11:52.855: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: PimEthAutoNeg: S2w Read/Write Error for port Fa5/3.
Jun 5 10:16:52.906: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: PimEthAutoNeg: S2w Read/Write Error for port Fa5/3.
Jun 5 10:21:53.057: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: PimEthAutoNeg: S2w Read/Write Error for port Fa5/28.
Jun 5 10:26:53.103: %C4K_SWITCHMANAGER-4-S2WERRORREPORT: PimEthAutoNeg: S2w Read/Write Error for port Fa5/28.
Power Fan Inline
Supply Model No Type Status Sensor Status
PS1 PWR-C45-2800AC AC 2800W good good good
PS2 PWR-C45-2800AC AC 2800W good good good
Power supplies needed by system : 1
Power supplies currently available : 2
Power Summary Maximum
(in Watts) Used Available
System Power (12V) 355 1360
Inline Power (-50V) 636 1400
Backplane Power (3.3V) 0 40
Total 991 2800
regards,
Jackal
Re: Power Supply problem
Hope this helps..
%C4K_SWITCHMANAGER-4-S2WERRORREPORT: PimEthAutoNeg: S2w Read/Write Error for port [char].
A read/write error occurred on the specified port.
Recommended Action: Refer to the release notes to verify whether you can see all the symptoms described for CSCef87815. If you do not and do not see any adverse effect on the functionality of the PoE linecards (WS-X4248-RJ45V, WS-X4248-RJ21V, WS-X4548-RJ45V, WS-X4224-RJ45V or WS-X4524-RJ45V), then treat this message an informational message only and no action is required.
Related documents- No specific documents apply to this error message.
More details on the bug id...
C4K_SWITCHMANAGER-4-S2WERRORREPORT and POE doesnot function
On Catalyst 4000/4500 series switches with 802.3af POE cards,
C4K_SWITCHMANAGER-4-S2WERRORREPORT message may be seen on console and POE
functionality
may be affected.
The following 802.3af POE cards are affected:
- WS-X4248-RJ45V
- WS-X4248-RJ21V
- WS-X4548-GB-RJ45V
- WS-X4224-RJ45V
- WS-X4524-GB-RJ45V
Problem:
Using 802.3af POE cards on Catalyst 4000/4500 series switches, phones may
never get power over ethernet and the connected links may never come up.
Disabling the POE functionality by configuring "power inline never" on a POE,
the interface can still link up when connected to non-POE devices. Few
S2WERRORREPORT messages may also be seen on the console.
Symptoms:
- C4K_SWITCHMANAGER-4-S2WERRORREPORT messages may be seen on console
- IP Phones that receive power from the connected ethernet ports of the
switch would lose power.
Workaround:
None.
Recommended Action:
Contact TAC to open a case.
regds
Community Member
thanks for reply. last month i have opened Tac case, they requested to change new module and we did change to new module. but now problem came back again . so, i was thinking maybe power problem ? because, i read the power detail which mentioned in module 5 only used 87 Watts.
3 WS-X4248-RJ45V 300 267 84 75 89
5 WS-X4248-RJ45V 87 77 11 10 89
Total 637 567 146 130
523
