Community Member
Power Supply temparture
What reason may be there that power supply temperature is critical .....its 127 degree celcius......threshold is 95
Where are you seeing this alert?
Solarwinds?
Community Member
its in cisco2951
router># show environment all
and also while taking console
What model of router/switch do you have?
Maybe you can try to look for the review information of your device and check if the values are normal, check the example for a 2800 serie http://www.cisco.com/c/en/us/td/docs/routers/access/2800/hardware/installation/guide/hw/01_hw.html#wp1027017 (look for Chassis Ventilation)
60
