Power to IE-3000-8TC
Just wanted to understand, does any Power Cable ships with IE-3000-8TC, I am using  this switch first time but not able to find any power cable.
  • LAN Switching and Routing
Had 20 ship for a project.
Had 20 ship for a project. None of the 50W or 65W power supplies came with power cords.
You will need to order the power cords separately. 18awg three prong power cord whip will be sufficient. I would tin the tips to avoid stray wire from crossing ground.
Here is what we used:
http://www.cablewholesale.com/products/power-products/power-cords/product-10w1-10106.php
Good Luck
These are Factory switches
These are Factory switches designed to run off the 24v DC  power that PLC's Use. It comes with a Terminal block to connect the 24V Dc .
That is why there is no AC P/s
Richard.
24
