ppp hostname, and router username
Hi all, On my dialer config I put a ppp chap hostname and password for the remote router, I then did a debug ppp negotation, it said no username found, so I set up a username under the global config and it worked, why is this, I thought that the ppp hostname should work ?
Re: ppp hostname, and router username
Hi carl,
When we configure the dialer config, router always look for the username and password configured on the router local database.It doesnot look for the Username password under the dialer interface. Please look at link below for config :
http://www.cisco.com/warp/public/793/access_dial/dialprofbridge.html
-amit singh
thanks, so why do we have the option for ppp chap hostname and password under the dialler interface ?
and this is the error i get :
ype escape sequence to abort.
Sending 5, 100-byte ICMP Echos to 172.21.247.100, timeout is 2 seconds:
04:12:139594876076: %LINK-3-UPDOWN: Interface BRI0:1, changed state to up
04:12:141733920767: %DIALER-6-BIND: Interface BR0:1 bound to profile Di1.
04:12:139586437093: BR0:1 PPP: Treating connection as a callout.
04:12:34: BR0:1 CHAP: O CHALLENGE id 39 len 31 from "TALKE-ISDN"
04:12:34: BR0:1 CHAP: I CHALLENGE id 151 len 31 from "wooldaler1"
04:12:34: BR0:1 CHAP: O RESPONSE id 151 len 31 from "TALKE-ISDN"
04:12:34: BR0:1 CHAP: I RESPONSE id 39 len 31 from "wooldaler1"
04:12:34: BR0:1 CHAP: O SUCCESS id 39 len 4
04:12:34: BR0:1 CHAP: I FAILURE id 151 len 17 msg is "Login Failure"
04:12:150323855360: %ISDN-6-DISCONNECT: Interface BRI0:1 disconnected from xxxxxxxxxxx wooldaler1, call lasted 3 seconds
04:12:152477698068: %LINK-3-UPDOWN: Interface BRI0:1, changed state to down.
04:12:150323855392: %DIALER-6-UNBIND: Interface BR0:1 unbound from profile Di1.
Success rate is 0 percent (0/5)
Hi Carl,
By default Cisco router identifies it self with its hostname.If you want override that hostname when the router negotiates with the peer router then we use that command " ppp chap hostname " under the interface. Plesae see the link below for more information
http://www.cisco.com/warp/public/471/understanding_ppp_chap.html#chapconfig
HTH, Please rate if it does.
-amit singh
i now have this working, via changing hostname.
cheers for your help
Carl
185
