Bronze
PPTP configuration
Is it possible to configure PPTP tunnel between two routers? If so can someone guide me through the config ?
1 REPLY
Silver
Re: PPTP configuration
You can terminate PPTP tunnels from hosts using PPTP with MPPEbut I'm don't believe you can configure a PPTP tunnel between two Cisco devices. You might want to look at the following doc though:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121newft/121t/121t5/dt_pptp.htm
Hope that helps - pls rate the post if it does.
265
