02-22-2012 09:37 AM - edited 03-07-2019 05:06 AM
I have a Cisco 4900M switch. It has two of the 8 port RJ-45 TenGig Ethernet cards in it. Was initially set up by a consultant.
I have used the first 8 ports on the first card. I just went to the 9th server, and now when I plug the ethernet cable into any of the 8 ports on the second card I get no link, nothing. The interface shows down, line protocol down (notconnect). A "show vlan" shows all the ports from BOTH cards are in Vlan1.
I did a "show tech support", and found some differences between the ports that work, and the ones that don't. Here are examples:
On a port that does not work the VlanID shows 4095. The STP state shows vlan 4095 (blocked)
On a port that does work the VlanID shows 1. The STP state shows vlan1 (forwarding).
So I think I found the issue, just don't know how to correct it.
Solved! Go to Solution.
02-22-2012 11:04 AM
Looking at what you have here, might be a bad module, maybe try re-seating it. If it does not work I presume, get Cisco TAC involved.
02-22-2012 10:04 AM
You need to assign the port you want to use to a particular vlan for it to work.
for example:
conf t
int gi0/9
switchport mode access
switchport access vlan 1
spanning-tree portfast
Hope that helps.
02-22-2012 10:23 AM
If the port is down and line protocol down (notconnect), then you have a layer-1 issue. Check your cable and make sure it is good.
02-22-2012 10:33 AM
Thanks for the replies.
Cable is OK, lights right up when unplugged from the 4900 port and put into a port on a 3750E.
Tried those commands. That did not work either. Nothing appears to have changed with the config, still showing 4095 and blocked.
There are some error messages in the tech-support: linecard-4-ethphyseuevent: te3/3 detected a soft error event--recovery process completed. See multiples of this.
02-22-2012 10:38 AM
can you post the following:
sh run int xxx {one for the interface that works and one for interface that does not work}
sh int xxx capabilities {one for the interface that works and one for interface that does not work}
sh vlan
02-22-2012 10:46 AM
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.02.22 12:38:13 =~=~=~=~=~=~=~=~=~=~=~= User Access Verification Password: Cisco-4900-Core>enable Password: Cisco-4900-Core#sho run inrt terface te3/3 Building configuration... Current configuration : 87 bytes ! interface TenGigabitEthernet3/3 switchport mode access spanning-tree portfast end Cisco-4900-Core#sho run interface te3/3 interface te3/3 interface te3/3 interface te3/3 interface te3/3 interface te3/3 capabilities TenGigabitEthernet3/3 Model: WS-X4908-10G-RJ45-RJ-45 Type: 10GBaseT Speed: 10000 Duplex: full Auto-MDIX: yes Trunk encap. type: 802.1Q Trunk mode: on,off,desirable,nonegotiate Channel: yes Broadcast suppression: percentage(0-100), hw Multicast suppression: percentage(0-100), hw Flowcontrol: rx-(off,on,desired),tx-(off,on,desired) VLAN Membership: static, dynamic Fast Start: yes CoS rewrite: yes ToS rewrite: yes Inline power: no SPAN: source/destination UDLD: yes Link Debounce: no Link Debounce Time: no Port Security: yes Dot1x: yes --More-- Maximum MTU: 9198 bytes (Jumbo Frames) Multiple Media Types: no Diagnostic Monitoring: N/A Queuing: rx-(N/A), tx-(1p7q1t) Cisco-4900-Core#sho sho interface te3/3 capabilities /3 capabilities 2/3 capabilities /3 capabilities TenGigabitEthernet2/3 Model: WS-X4908-10G-RJ45-RJ-45 Type: 10GBaseT Speed: 10000 Duplex: full Auto-MDIX: yes Trunk encap. type: 802.1Q Trunk mode: on,off,desirable,nonegotiate Channel: yes Broadcast suppression: percentage(0-100), hw Multicast suppression: percentage(0-100), hw Flowcontrol: rx-(off,on,desired),tx-(off,on,desired) VLAN Membership: static, dynamic Fast Start: yes CoS rewrite: yes ToS rewrite: yes Inline power: no SPAN: source/destination UDLD: yes Link Debounce: no Link Debounce Time: no Port Security: yes Dot1x: yes --More-- Maximum MTU: 9198 bytes (Jumbo Frames) Multiple Media Types: no Diagnostic Monitoring: N/A Queuing: rx-(N/A), tx-(1p7q1t) Cisco-4900-Core#sho run interface te2/3 Building configuration... Current configuration : 87 bytes ! interface TenGigabitEthernet2/3 switchport mode access spanning-tree portfast end Cisco-4900-Core#sho vlan VLAN Name Status Ports ---- -------------------------------- --------- ------------------------------- 1 default active Te1/1, Te1/2, Te1/3, Te1/7 Te2/1, Te2/2, Te2/3, Te2/4 Te2/5, Te2/6, Te2/7, Te2/8 Gi2/9, Gi2/10, Gi2/11, Gi2/12 Gi2/13, Gi2/14, Gi2/15, Gi2/16 Te3/1, Te3/2, Te3/3, Te3/4 Te3/5, Te3/6, Te3/7, Te3/8 Gi3/9, Gi3/10, Gi3/11, Gi3/12 Gi3/13, Gi3/14, Gi3/15, Gi3/16 10 Voice-Servers active 110 Data active 111 Voice active 112 Wireless-User active 113 Wireless-mgmt active 1002 fddi-default act/unsup 1003 token-ring-default act/unsup 1004 fddinet-default act/unsup 1005 trnet-default act/unsup VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2 --More-- ---- ----- ---------- ----- ------ ------ -------- ---- -------- ------ ------ 1 enet 100001 1500 - - - - - 0 0 10 enet 100010 1500 - - - - - 0 0 110 enet 100110 1500 - - - - - 0 0 111 enet 100111 1500 - - - - - 0 0 112 enet 100112 1500 - - - - - 0 0 113 enet 100113 1500 - - - - - 0 0 1002 fddi 101002 1500 - - - - - 0 0 1003 tr 101003 1500 - - - - - 0 0 1004 fdnet 101004 1500 - - - ieee - 0 0 1005 trnet 101005 1500 - - - ibm - 0 0 Remote SPAN VLANs ------------------------------------------------------------------------------ Primary Secondary Type Ports ------- --------- ----------------- ------------------------------------------ Cisco-4900-Core# Port te2/3 works, te3/3 does not.
02-22-2012 10:58 AM
Boy is that ugly. Cut and paste don't work so well.
02-22-2012 11:04 AM
02-23-2012 06:30 AM
Cisco tech support agrees. They are sending a new card. Thanks!
