Problème VTP sur Cisco 4506
I have a problem with creation domain VTP between two equipments cisco, a Cisco 6506 and a Cisco 4506
The two equipments are relied with a fiber optic and trunking ports is configured in each equipment.
I want to create 2 domain VTP.
You can see the error message
Can you help me ?
Bonjour
j'ai un problème de création de domaine VTP, entre un 6506 et un 4506.
Les deux sont reliés en fibre optique sur des ports TRUNK, je souhaite créer 2 domaines VTP, l'un sur mon réseau du 6506 et l'autre sur le réseau
du 4506.
Voici le message d'erreur sur le Cisco 4506
Pouve-vous m'aider ?
Jul  3 07:39:38: %SYS-5-CONFIG_I: Configured from console by console
Jul  3 07:40:55: %DTP-5-DOMAINMISMATCH: Unable to perform trunk negotiation on port Gi2/11 because of VTP domain mismatch.
Jul  3 07:40:55: %DTP-5-DOMAINMISMATCH: Unable to perform trunk negotiation on port Gi2/1 because of VTP domain mismatch.
Jul  3 07:40:55: %DTP-5-DOMAINMISMATCH: Unable to perform trunk negotiation on port Gi1/1 because of VTP domain mismatch.
Jul  3 07:40:55: %DTP-5-DOMAINMISMATCH: Unable to perform trunk negotiation on port Gi4/2 because of VTP domain mismatch.
Jul  3 07:40:55: %DTP-5-DOMAINMISMATCH: Unable to perform trunk negotiation on port Gi4/1 because of VTP domain mismatch.
Jul  3 07:40:55: %SYS-5-CONFIG_I: Configured from console by console
Jul  3 07:40:55: %DTP-5-DOMAINMISMATCH: Unable to perform trunk negotiation on port Gi1/2 because of VTP domain mismatch.
.Jul  3 07:48:05: %SYS-5-CONFIG_I: Configured from console by console
.Jul  3 07:52:04: %SYS-5-CONFIG_I: Configured from console by console
.Jul  3 07:57:56: %SYS-5-CONFIG_I: Configured from console by console
Re: Problème VTP sur Cisco 4506
Bonjour
du 4506.
Unable to understand the laguage written above,But as per the log check the vtp domain configured in server and rest of the switches.It should be same in order to work.
Hope to Help !!
Ganesh.H
A VTP domain is made up of one or more interconnected network devices that share the same VTP domain name. A network device can be configured to be in only one VTP domain.
I think you are trying to configure more than 1 vtp domain on single device
Hitesh Vinzoda
Pls rate useful posts
I configured VTP domain in two network different, One relied in 6506 and other in 4506
Configuration 6506: Domain toto, vtp mode server, VTP V2 Mode, VTP Pruning Mode Enabled
Configuration 4506: Domain titi, vtp mode server, VTP V2 Mode, VTP Pruning Mode Enabled
You have a trunk link between 6500 and 4500, which is making VTP traffic to flow across and leading the mismatch of VTP domain
Hitesh Vinzoda
As hitesh pointed the right thing you have trunk link between the two switches, If your VTP domains do not match on each side of a trunk link, then DTP will NOT work.  You need to watch out for this as the ports will be up/up, but trunking will not be negotiated.  You’ll need to either make both VTP domains the same, or hard-set the trunks with “switchport nonegotiate”.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
666
