Problem Configuring Nat On a Stick
I'm trying to configure NAT on a stick just as a learning exercise in my home network. I followed the instructions on Cisco's website (http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094430.shtml)and also an article on techrepublic (http://blogs.techrepublic.com.com/networking/?p=486) that showed how to configure nat on a stick.
My setup is as follows
Comcast Connection
68.33.x.x IP address
to
Netgear Router
The netgear's gateway is 192.168.0.1 and it leases 192.168.0.10 to one computer on my home network
Right now, I have a hub connected between the Netgear router, the Cisco 2610, and the Windows PC that I will use to get on the internet. The Netgear router hooks into the uplink port on the Hub. The Cisco, and the PC all hook into 2 of the other ports.
The first question I have is whether or not it is better to have a switch or a hub in order to make this work? I know all of the advantages of using a switch but the techrepublic article specifically mentioned using a hub. Is there a reason or will either one work for this type of setup?
I'm trying to configure in a similar fashion as to what both articles said.
Here is my setup
interface Loopback0
ip address 10.0.1.1 255.255.255.252
ip nat outside
interface Ethernet0/0
ip address 192.168.0.2 255.255.255.0 secondary
ip address 10.0.0.2 255.255.255.0
ip nat inside
ip policy route-map Nat-loop
half-duplex
ip nat pool external 192.168.0.10 192.168.0.10 prefix-length 29
ip nat inside source list 10 pool external overload
ip http server
no ip http secure-server
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip route 192.168.0.0 255.255.255.0 Ethernet0/0
access-list 10 permit 10.0.0.0 0.0.0.255
access-list 102 permit ip 10.0.0.0 0.0.0.255 any
access-list 102 permit ip any 192.168.0.0 0.0.0.255
route-map Nat-loop permit 10
match ip address 102
set ip next-hop 10.0.1.2
My router isn't able to connect to anything outside of the local network. Even doing a traceroute to an external IP is not working?
Please advise
Re: Problem Configuring Nat On a Stick
Keith,
Try the below,
set interface loopback 0
Now change, the NAT inside/outside as below,
ip nat inside
interface e0/0
ip nat outside
In your config NAT inside and outside is configured in wrong interfaces.
With the new config, Your PBR will forward the packet to loopback interface. Now the packet will be looped and send back from loopback interface to E0/0 (inside i/f to outside i/f) and your NAT will kick in.
HTH,
Nagendra
hi,
try this:
no set ip next-hop 10.0.1.2
set interface loopback0
regards
romek
169
