Problem from upgrade DFC to DFC3A on WS-X6816-GBIC
bathory0110
I'm use DFC3A upgrade from DFC for 720-3B. But when install line Card (WS-X6816-GBIC) this log is show.
Sep 9 09:17:06.031: %DIAG-SP-6-RUN_MINIMUM: Module 1: Running Minimal Diagnostics...
Sep 9 09:18:08.061: %DIAG-SP-3-MAJOR: Module 1: Online Diagnostics detected a Major Error. Please use 'show diagnostic result <target>' to see test results.
Sep 9 09:18:08.085: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 1: TestLoopback failed on port(s) 1-16
Sep 9 09:18:08.085: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 1: TestConditionalLearn failed
Sep 9 09:18:08.085: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 1: TestMacNotification failed
Sep 9 09:18:08.085: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 1: TestFibDevices failed
Sep 9 09:18:08.085: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 1: TestIPv4FibShortcut failed
Sep 9 09:18:08.085: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 1: TestIPv6FibShortcut failed
Sep 9 09:18:08.085: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 1: TestNATFibShortcut failed
Sep 9 09:18:08.085: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 1: TestMPLSFibShortcut failed
Sep 9 09:18:08.085: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 1: TestL3VlanMet failed
Sep 9 09:18:08.085: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 1: TestIngressSpan failed
Sep 9 09:18:08.085: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 1: TestEgressSpan failed
Sep 9 09:18:08.085: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 1: TestAclPermit failed
Sep 9 09:18:08.085: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 1: TestAclDeny failed
Sep 9 09:18:08.085: %CONST_DIAG-SP-3-BOOTUP_TEST_FAIL: Module 1: TestQos failed
Sep 9 09:18:08.261: %OIR-SP-3-LC_FAILURE: Module 1 has Major online diagnostic failure, Card will be powered reset to re-run diagnostic. Please check bootflash diaginfo file for previous detailed diagnostic result.
Sep 9 09:18:08.293: %C6KPWR-SP-4-DISABLED: power to module in slot 1 set off (Reset)
Please help me
satya.singh
can we try to Re-seat the card and retry the test.
