03-19-2008 01:05 PM - edited 03-05-2019 09:51 PM
Is someone who can help me? What is the meaning of the result "%Network not in table"?
Router>show int serial1
Serial1 is up, line protocol is down
Hardware is MK5025
Description: ****Example****
Internet address is 192.168.1.1/30
MTU 1500 bytes, BW 512 Kbit, DLY 20000 usec, rely 131/255, load 1/255
Encapsulation PPP, loopback not set, keepalive set (10 sec)
LCP Listen
Closed: IPCP, CDPCP
Last input 00:07:58, output 00:00:14, output hang never
Last clearing of "show interface" counters 12:50:32
Input queue: 0/75/0 (size/max/drops); Total output drops: 0
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/75/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
92 packets input, 7719 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
29464045 input errors, 29253742 CRC, 0 frame, 210307 overrun, 0 ignored, 0 abort
9611 packets output, 134554 bytes, 0 underruns
0 output errors, 0 collisions, 2415 interface resets
2451 carrier transitions
Router>show ip route 192.168.1.1
% Network not in table
Router>
03-19-2008 01:08 PM
The Serial interface is not up/up, it sees a physical connection but no protocol.
The connected 192.168.1.1 address will only be in the routing table if interface and line protocol are both up.. This is a PPP encapsulated interface and it appears possible the other end of the PPP link isn't uup or configured properly.
03-19-2008 02:03 PM
Now I understand. Thanks for the answer. :)
May I know what are the other factor of going down of the line protocol (Line protocol is down)? Can you give me an other scenarios or examples?
Thanks in advance..
Martee Sacramento
03-19-2008 02:09 PM
There are many scenarios. I use a mostly HDLC encapsulated serial interfaces on leased T-1 circuits, a reason line protocol could be down might include the telco provider having some of its switch gear down or not working right.
Here's the Cisco direction for PPP interfaces.
http://www.cisco.com/en/US/tech/tk482/tk607/technologies_white_paper09186a0080094699.shtml
