Problem recognizing NM-NAM in router
I've just installed an NM-NAM in a 3825 running 15.1 and the card is seen an initial boot, but can't be seen when iOS is booted - throws the errors below in this abridged concole output - the card also doesn't have a CF card - is that an issue?
Initializing ATA monitor library.......
program load complete, entry point: 0x8000f000, size: 0xc0c0
program load complete, entry point: 0x80010000, size: 0x40c2dac
Self decompressing the image : ############################################################################################################################################################################################################################################################################################################################################################################################################################# [OK]
Smart Init is enabled
smart init is sizing iomem
  ID            MEMORY_REQ                 TYPE
00042A          0X010D78F3 C3825 motherboard
00046A          0X0004FE00 NAM Sensor NM
0002A9          0X001E4E2F 16 port ethernet switch
                0X00288860 Onboard PVDM2 SIMM
                0X0027250A Onboard VPN
                0X000021B8 Onboard USB
                0X00660670 public buffer pools
                0X0078F000 public particle pools
TOTAL:          0X025F8AB4
export@cisco.com.
Installed image archive
Cisco 3825 (revision 1.1) with 485376K/38912K bytes of memory.
Processor board ID FTX1014A0K8
16 FastEthernet interfaces
3 Gigabit Ethernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
126000K bytes of ATA System CompactFlash (Read/Write)
Press RETURN to get started!
*Sep  6 22:41:31.751: %I82559FE-1-NOT82559: NM slot 1: PCI device ID seen as 0xFFFFFFFF, expected 0x12298086
*Sep  6 22:41:31.751: %JETFIRE_SM-1-INITFAIL: NM slot 1: PCI device 0 initialization failed
127
