Problem switch stack 3750
andreas.plaul
we have a problem with our switch stack.
Currently we have 9 switches in the (2 GigabitEthernet Switches and 7 FastEthernet Switches).
Basically the transfer rate between Servers and Users located on different switches is creating speed problems.
Please see the following details:
1)Correct speed:
Server/User -> GigabitEthernet Switch -> Server/User
Server/User -> GigabitEthernet Switch -> GigabitEthernet Switch -> Server/User
Server/User -> FastEthernet Switch -> Server/User
Server/User -> FastEthernet Switch -> FastEthernet Switch -> Server/User
2) Very slow speed (~100Kbits):
Server/User -> FastEthernet Switch -> GigabitEthernet Switch -> Server/User
As most of our users are connected via option 2) they have the most problems.
Mainly it looks like the FastEthernet switches are not able to communicate at full speed via the stack with the Gigabit switches.
Any ideas?
Best regards,
Andreas Plaul
7 Replies 7
glen.grant
Look for obvious stuff first like your connections between your switches , do you have speed/duplex mismatches on the links , are you seeing errors etc... Look at user ports also for the same problems . If you are usuing cisco switches do a show int status and look for any interfaces that are showing half duplex , this is usually a mismatch scenario . If you are unsure then hardcode the speed/duplex to 100/full on "both" ends of any connecting links. You should be seeing very little speed degradation just by adding a fast ether to a gig switch. You can check link utilization also between the switches , usually this is not a problem unless you are getting over 80 % link utilization .
A further point on Glen's comment. What version of software are you using on the 3750s?
Some versions have problems that cause previously configured switch ports to drop back to autonegotiation. This is a problem if both ends were statically configured to full duplex!
check by doing a sh int at each end.
Paul.
Another obvious one to check:
Server adapter teaming is known to cause similar behaviour, especially since you are stating that it happens on the switches where the server is not connected. Dissolve the team and test for speed increases.
regards,
Leo
Hello all,
thanks for the replys.
First the IOS on the switches is: 12.2(20)SE3.
The checking of the counters / errors on the interfaces doesn't show any big numbers.
So basically:
sh interfaces counters errors
sh interfaces
are looking good.
Igijssel, you are right the worst performance we see on the communication between a NAS (Netapp) with Etherchannel (4x Gigabit) and the users on the FastEthernet switches.
Configuration of the Etherchannel and the ports:
interface Port-channel1
switchport trunk allowed vlan xxx
switchport mode trunk
switchport nonegotiate
bandwidth 4000000
speed 1000
flowcontrol receive desired
interface GigabitEthernet1/0/1
speed 1000
channel-group 1 mode on
spanning-tree portfast trunk
interface GigabitEthernet1/0/2
speed 1000
Here are the speed findings:
From What To Speed
FastEthernet upload GigabitEthernet 80Mbits
FastEthernet download GigabitEthernet 57Mbits
GigabitEthernet upload FastEthernet 32Mbits
GigabitEthernet download FastEthernet 53Mbits
GigabitEthernet upload GigabitEthernet 573Mbits
GigabitEthernet download GigabitEthernet 245Mbits
FastEthernet upload Etherchannel (4xGiga) 57Mbits
FastEthernet download Etherchannel (4xGiga) 400Kbits
GigabitEthernet upload Etherchannel (4xGiga) 163Mbits
GigabitEthernet download Etherchannel (4xGiga) 245Mbits
Please have a look on the config, maybe I am doing somwthing wrong.
Best regards,
Andreas Plaul
I am testing now with a simple one port connection between the NAS (1 Gigabit) to a client (100Mbits). Still very slow connection (400Kbits).
When I force the interface on Netapp side to 100Mbits, it works on full speed. Changing back (Auto -> 1Gbit) it slows to 400Kbits.
Also checked the cabling which is correct (trie multiple Cat5e cables).
Maybe this helps, I am out of ideas.
Best regards,
Andreas Plaul
When at auto, whar speed/duplex does the switch report? What does the server report? Are there any errors in the counters on the switch? can uou get stats from the server?
yesterday for testing we disabled "mls qos" on the whole stack and that solved the speed issue. Looks like we hit this bug:
CSCsc96037: "CAT3560 / 3750:QoS causes slow TCP performance"
"Configuring Quality of Service on a CAT3560 or CAT3750 running any IOS can cause certain TCP applications such as NFS to run slower.
We will test the 12.2(37)SE1 IOS and see if it fixes the issue.
Best regards,
Andreas Plaul
