Community Member
Problem while applying configuration to SCE 8000 using SCE-API
We are facing an issue while applying service configuration to SCE 8000 device using SCE API supplied by CISCO.
We have sample .pqb file which we are using to upload to SCE 8000. We are using 3.5.5 version of firmware on SCE.
Attached is exception file which contains sample .pqb and trace log that we see when we apply configuration. Please note, that we are using RHEL5 platform, JDK 1.5.0_1 and standalone java program to apply configuration on SCE using API
com.pcube.management.common.InvocationException: null ### java.lang.NullPointerException java.lang.NullPointerException
        at com.pcube.management.framework.fsmanager.RFileInputStream.close(RFileInputStream.java:240)
        at java.io.BufferedInputStream.close(BufferedInputStream.java:440)
        at com.pcube.apps.engage.management.Utilities.copyDeviceToLocalRMI(Utilities.java:357)
        at com.pcube.apps.engage.policy.ConfigurationRetriever.retrievePolicy(ConfigurationRetriever.java:85)
        at com.pcube.apps.engage.policy.Test.fetchPpUpgradeVersion(Test.java:15)
        at com.elitecore.pm.SCEConfiguration.main(SCEConfiguration.java:460)
failed to fetch current pp upgrade version listjava.lang.NullPointerException0.0.0 PP0com.pcube.apps.engage.common.ApplyException: Client version 3.5.5 PP20 is different than SCE version 0.0.0 PP0, therefore apply is not allowed
        at com.pcube.apps.engage.policy.SEPolicyMediator.checkPpVersion(SEPolicyMediator.java:335)
        at com.pcube.apps.engage.policy.SEPolicyMediator.applyPolicy(SEPolicyMediator.java:114)
        at com.pcube.apps.engage.policy.SEPolicyMediator.applyPolicy(SEPolicyMediator.java:95)
        at com.elitecore.pm.SCEConfiguration.main(SCEConfiguration.java:461)
311
