01-17-2007 08:15 PM - edited 03-05-2019 01:50 PM
Dear all,
would like to know if anyone of u experience the following problem.
i'm have 2 units of 2960TTL 24 at my office. and each of it has a port being disable.
when i type sh interface status.
there's an err-disable at the status.
i cant seem to enable it inside CNA.
the error msg in CNA is that
a loopback has been detected and it recommended to run smartport.
both port were initially plugged in with a linksys which, which is no longer connected now.
i've tried to remove configuration on the respective port and the error is still there. should i reset the configuration to factory default?
or the port is faulty?
please advice. thank you.
Solved! Go to Solution.
01-17-2007 08:50 PM
It seems that port is in err-disable state. To recover it from that state, you need to "shut" and then "no shut" the port.
int fa0/1
shutdown
no shutdown
HTH, rate if it does ...
01-18-2007 12:44 AM
A port may be put into errordisable state for a lot of reasons ( loopback detected, UDLD, link-flap, PAgp flap, BPDU guard etc)
There are 2 ways to recover from this state.
Either do a shut , no shut on the interface or you should have the following command configured globally
errdisable recovery cause
What you should be really looking at is the cause which is forcing the ports to go errordisable...time to relook at your design so that the incident does not repeat
Narayan
01-17-2007 08:50 PM
int fa0/1
shutdown
no shutdown
01-17-2007 09:52 PM
let me try.
will get back to you asap.
thanks for replying.
02-03-2007 08:11 AM
hi there
manage to solve the problem.
thanx alot.
really appreciate it.
brandon.
01-17-2007 09:19 PM
Can you perform a shut and no shut on these ports.
-VJ
01-17-2007 09:49 PM
let me try.
01-18-2007 12:44 AM
Narayan
02-03-2007 08:17 AM
hi there
thanx alot.
but wat would likely be the cause of this?
brandon.
02-03-2007 01:08 PM
Should tell you in the logs why it err-disabled the port .
