Problem with Cisco 1841 Router
gagarwal4
I am facing problem with my cisco 1841 router and it is not giving me console accese. Please find router logs as below -
Readonly ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
program load complete, entry point: 0x8000f000, size: 0xd4a9a0
Self decompressing the image : #################################################
######## [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
0X003AA110 public buffer pools
0X00211000 public particle pools
0X000021B8 Onboard USB
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Allocating additional 7713952 bytes to IO Memory.
PMem allocated: 117440512 bytes; IOMem allocated: 16777216 bytes
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.4(1c), RELEASE SO
FTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 25-Oct-05 17:10 by evmiller
Image text-base: 0x6007ECA0, data-base: 0x61480000
Port Statistics for unclassified packets is not turned on.
Cisco 1841 (revision 7.0) with 114688K/16384K bytes of memory.
Processor board ID FHK122222J7
2 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31360K bytes of ATA CompactFlash (Read/Write)
username cisco privilege 15 one-time secret 0 cisco
% Invalid input detected at '^' marker.
ip http secure-server
transport input telnet ssh
It looks like you may need to do a password recovery on the router. I see from the output that it did not accept the username in the config. It also looks like you went from a crypto IOS to a non crypto IOS. Here are instructions on how to run a password recovery.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_password_recovery09186a0080094675.shtml
HTH,
Mark
5 Replies 5
satish_zanjurne
Level 4
Level 4
Are you getting the telnet access ??
no.. infact i am not able to access it through console
no.. i don't get console access also
HTH,
Mark
Hi Mate ,
what if i have password recovery mechanism disabled.. in that case what the next option...
thanks
