Webcast-Catalyst9k
Problem with default router via Static DHCP
Hi all!
Here is a problem with static DHCP. I have 2 DHCP pools on a router for 2 ethernet subinterfaces:
ip dhcp pool First_Insurance
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
ip dhcp pool Netassets
network 192.168.4.0 255.255.255.0
default-router 192.168.4.1
interface FastEthernet0/1.2
description First_Insurance
encapsulation dot1Q 2
ip address 192.168.2.1 255.255.255.0
ip access-group First_Insurance_in in
ip nat inside
ip virtual-reassembly
no cdp enable
interface FastEthernet0/1.4
description Netassets
encapsulation dot1Q 4
ip address 192.168.4.1 255.255.255.0
ip access-group Netassets_in in
ip nat inside
no cdp enable
Also there is DHCP pool for binding IP to MAC:
ip dhcp pool Static
origin file tftp://xxx.xxx.xxx.xxx/dhcp/static.txt
TFTP server contains a file with MAC-IP mapping, for example:
192.168.4.2 /24 id 0100.0d61.4520.e3 Infinite
But when a workstation with MAC 000d.6145.20e3 try to obtain information via DHCP it receive address 192.168.4.2 and default router 192.168.2.1!
Where is a problem??
Re: Problem with default router via Static DHCP
can you juz release release & renew the ip address on the workstation, also try clearing the dhcp binding database.
in workstation
ipconfig /release
ipconfig /renew
in router
router#clear ip dhcp binding *
where * meanz clear all bounded ip addresses.
also i could never see any gateway information in the tftp server mapped file i.e static.txt
Ofcourse, i've try to release and renew on workstation - no effect. Same effect from clear ip dhcp binding * and from no service dhcp - ser vice dhcp. Debug DHCP shows this:
Apr 17 10:48:57.952: DHCPD: Sending notification of DISCOVER:
Apr 17 10:48:57.952: DHCPD: htype 1 chaddr 0013.4622.1eda
Apr 17 10:48:57.952: DHCPD: remote id 020a0000c0a8050101000005
Apr 17 10:48:57.952: DHCPD: circuit id 00000000
Apr 17 10:48:57.952: DHCPD: Seeing if there is an internally specified pool class:
Apr 17 10:48:57.952: DHCPD: child pool: 192.168.2.2 / 255.255.255.0 (Static)
Apr 17 10:48:57.952: DHCPD: parent pool: 192.168.2.0 / 255.255.255.0 (First_Insurance)
Apr 17 10:48:57.952: DHCPD: child pool: 192.168.2.0 / 255.255.255.0 (First_Insurance)
Apr 17 10:48:57.952: DHCPD: pool First_Insurance has no parent.
Apr 17 10:48:57.956: DHCPD: Sending notification of ASSIGNMENT:
Apr 17 10:48:57.956: DHCPD: address 192.168.5.7 mask 255.255.255.0
Apr 17 10:48:57.956: DHCPD: htype 1 chaddr 0013.4622.1eda
Apr 17 10:48:57.956: DHCPD: lease time remaining (secs) = 4294967295
Hall of Fame Super Gold
Dmitry
Does the static pool have any definition of default router?
On which interface is the request from the PC with the matching MAC address arrive?
Rick
Static pool have no any definitions of default router, request arriving on interface fa0/1.5 with address 192.168.5.1
288
