Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Problem with ping
Hello
I recently changed my company's router with a cisco 1941 k9 and i have a problem......
I can not ping from inside the router the a distinct network but when i try to ping from my server the same network the ping passes. The same occurs when i try to trace route the same network.
Any clue why is this happening???
1 ACCEPTED SOLUTION
Problem with ping
Hi Evangelos,
It seems to be remote side not having route to NW configured on S0/0/0. Or there is an access-list blocking access to it between your router and distinct location. Your ISP or anyone who has access through the WAN path need to check that.
Nik
VIP Super Bronze
Problem with ping
maybe your router does not have a route to the distinct network. Can you provide a diagram of the network and what you are trying to reach? Also can you post 1941 config?
Problem with ping
The only static route that my router has is 0.0.0.0 0.0.0.0 10.248.0.17
10.248.0.17 is the serial interface ot the provider
AIA_Router#show run
Building configuration...
Current configuration : 4884 bytes
! Last configuration change at 15:15:13 UTC Fri Nov 4 2011 by administrator
version 15.0
hostname AIA_Router
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip domain name yourdomain.com
crypto pki trustpoint TP-self-signed-2937537602
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2937537602
revocation-check none
rsakeypair TP-self-signed-2937537602
crypto pki certificate chain TP-self-signed-2937537602
certificate self-signed 01
  30820251 308201BA A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32393337 35333736 3032301E 170D3131 30393330 30383435
  35395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 39333735
  33373630 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100C78C 39F3885A B9703214 F3C6BABE 228CCCD2 57B5E817 D3EABA82 73E104CA
  0C32556E 766423B7 BF2BDBF1 A163773E B14EFFFA 9BE6684D 03C394C1 7CA9193F
  563EF8CE 9F95646E 187A6E3C 3B713239 76045850 4D793D48 C7972933 95966B07
  7EE429CC 6A262D2B 6AA6F4E8 5FBA8219 B515CD04 C94701F0 BE731441 FF575AB8
  AE710203 010001A3 79307730 0F060355 1D130101 FF040530 030101FF 30240603
  551D1104 1D301B82 19414941 5F526F75 7465722E 796F7572 646F6D61 696E2E63
  6F6D301F 0603551D 23041830 168014B2 17DC0FCD 5E997695 E17D83E0 A8EAB5EC
  30C00D30 1D060355 1D0E0416 0414B217 DC0FCD5E 997695E1 7D83E0A8 EAB5EC30
  C00D300D 06092A86 4886F70D 01010405 00038181 007DAF9A 6A72662F 76416B79
  EA04341A C373F76A 935B5FB5 835BA9FD 93BDBC88 A5AD489F 8CE6BC0B 3E6DED92
  030BF11F 27A48AAE 60A5A5DB D643359A 633FF6BD 17A116B0 D96D13D4 D3DD497C
  FFDD3352 785BF7AC 464D8F86 6F390F01 86534A0A CAF030F2 91FFFA05 D762FFE2
  EB87B99E D6B3A06F FA8BA6DF C22E9DB0 1082CAA1 B4
        quit
license udi pid CISCO1941/K9 sn FCZ152891DK
username administrator privilege 15 secret 5 $1$wEwc$MYvRtZopMlwLSJxw3Er571
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 172.27.11.10 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 10.102.50.1 255.255.255.0
shutdown
duplex auto
speed auto
interface Serial0/0/0
ip address 10.248.0.18 255.255.255.252
encapsulation ppp
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 10.248.0.17
control-plane
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username privilege 15 secret 0
Replace and with the username and password you want to
use.
^C
banner login ^C
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE  PUBLICLY-KNOWN
CREDENTIALS
Here are the Cisco IOS commands.
no username cisco
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL NOT BE ABLE
TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
^C
line con 0
login local
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
Thank you in Advanced!!!!!!
Purple
Problem with ping
Which network are you trying to reach and from where is it failing.
Could you post the results of what is working and what is failing.
Alain
Hall of Fame Super Silver
Problem with ping
I agree that having some specifics of what is working and what is not working would help us figure out what is going on.
I do not see any address translation in the configuration that is posted. So I wonder if the provider is doing address translation. And that makes me wonder if the problem might be related to address translation. My theory is that the problem relates to the fact that the ping and traceroute from the server would have a source address in the subnet of one of the Gig interfaces while ping and traceroute from the router will have the source address of the serial interface. Perhaps there is address translation for the subnets on Gig but not translation for the subnet on the serial interface?
One way to test this would be to use extended ping and tracearoute on the router. In the extended ping and traceroute you have an option to specify the source interface. So try extended ping and traceroute where you specify the source address for the router as the Gig interface where the server is connected.
Rick
Problem with ping
Hello
The gig0/0 interface is directly connected to my network while the serial interface s0/0/0 is connected with the provider's modem. You are right Ritchard when i try extended ping with source interface the gig interface the ping passes while when i try to ping from the serial interfaces it doesn't passes.
Any suggestions on what I should do?
Thanks in advanced
Problem with ping
Hi Evangelos,
Nik
Problem with ping
Thank you Nikolay you were right i just contacted my isp and he confirmed me the malfunction
552
