10-18-2010 12:35 PM - edited 03-06-2019 01:35 PM
Switch#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch(config)#interface Vlan2 Switch(config-if)#ip address 10.1.2.1 255.255.255.0 Switch(config-if)#no shutdown
Switch(config)#interface FastEthernet 0/1 Switch(config-if)#no switchport Switch(config-if)#ip address 200.1.1.1 255.255.255.0 Switch(config-if)#no shutdown
Switch(config)#ip route 0.0.0.0 0.0.0.0 200.1.1.2
The ip 20.1.1.2 is not pingabile.
How can I ping 20.1.1.2 and a possible DNS server with ip 20.1.1.10?
Solved! Go to Solution.
10-19-2010 12:31 PM
Perhaps there is some hidden ACL that blocks traffic?
If I use 10.10.10.138 to go on the internet because I do not ping.
Why can not I access the web page http://10.10.10.138?
Switch#ping ip 10.10.10.138 source 10.10.10.80
Sending 5, 100-byte ICMP Echos to 10.10.10.138, timeout is 2 seconds:
Packet sent with a source address of 10.10.10.80
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/9 ms
Switch#ping ip 10.10.10.138 source 192.168.0.1
Packet sent with a source address of 192.168.0.1
Success rate is 0 percent (0/5)
Switch#ping ip www.google.it source 192.168.0.1
Translating "www.google.it"...domain server (255.255.255.255) [OK]
Sending 5, 100-byte ICMP Echos to 209.85.135.99, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 109/112/118 ms
10-19-2010 01:34 PM
Switch#ping ip 10.10.10.138 source 192.168.0.1Type escape sequence to abort.
Switch#ping ip www.google.it source 192.168.0.1Translating "www.google.it"...domain server (255.255.255.255) [OK]
I suspect as you say there is something on the router that is blocking the packets coming back. If you can ping an internet address from 192.168.0.1 then the default router has a route back to the 192.168.0.x network or else that ping would not work.
Jon
10-19-2010 11:11 PM
Hello Claudio,
So what all we have seen so far is that there is definetly a route back to 192.168.0.x network on the public router, however it seems there is some ACL that could be blocing the pings.
The best way to troubleshoot what the exact root cause is now (also, conidering the fact that you do not have access to the public router) is to CONFIGURE A SPAN on the switch to take packet captures on any of the 192.168.0.x machines using wireshark. This will show us a complete picture and details.
Kindlu use following link to configure local span :
/Akhil
10-20-2010 08:15 AM
What should I look for wireshark?
10-21-2010 02:41 AM
Hello Claudio,
Indeed. Yes, Wireshark on a machine which is connected on destination port of a local span session.
/Akhil
10-21-2010 05:36 AM
10-21-2010 11:24 AM
Hello Akhil,
I managed to get into the router 10.10.10.138, I set route 192.168.0.0 255.255.255.0 10.10.10.80 and now everything works.
this is right?
There are packages that bounce between the switch and the router?
If I had not had access to the router?
Thank you all
Claudio.
10-21-2010 12:42 PM
Claudio,
I'm glad it worked. I am also glad I did not steer you wrong. Please be sure to rate my response
10-25-2010 01:17 AM
Hello, I have one more question.
you can enable NAT on Catalyst 3750?
Claudio.
10-19-2010 11:20 AM
Claudio
Can you provide the output of an "ipconfig /all" from 10.10.10.1 ? It looks to me like it doesn't have a default-gateway set.
Jon
10-19-2010 11:30 AM
IPCONFIG MY DNS SERVER
C:\Documents and Settings\Administrator>ipconfig /all
Configurazione IP di Windows
Nome host . . . . . . . . . . . . . . : sr01
Suffisso DNS primario . . . . . . . . : cart.local
Tipo nodo . . . . . . . . . . . . . . : Broadcast
Routing IP abilitato . . . . . . . . : Sì
Proxy WINS abilitato . . . . . . . . : Sì
Elenco di ricerca suffissi DNS. . . . : cart.local
Scheda Ethernet Connessione alla rete locale (LAN):
Suffisso DNS specifico per connessione:
Descrizione . . . . . . . . . . . . . : HP NC105i PCIe Gigabit Server Adapter
Indirizzo fisico. . . . . . . . . . . : 00-21-5A-2F-D8-E1
DHCP abilitato. . . . . . . . . . . . : No
Indirizzo IP. . . . . . . . . . . . . : 10.10.10.1
Subnet mask . . . . . . . . . . . . . : 255.255.255.0
Gateway predefinito . . . . . . . . . : 10.10.10.138
Server DNS . . . . . . . . . . . . . : 127.0.0.1
PING from CISCO 3750
Switch>
Switch>en
Switch#ping 10.10.10.1
Sending 5, 100-byte ICMP Echos to 10.10.10.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/8 ms
Switch#ping 10.0.0.250
Sending 5, 100-byte ICMP Echos to 10.0.0.250, timeout is 2 seconds:
Switch#ping 192.168.0.10
Sending 5, 100-byte ICMP Echos to 192.168.0.10, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
10-19-2010 11:34 AM
Hello Claudio,
Thanks. Can you please do following from 3750 switch :
/Akhil
Elenco di ricerca suffissi DNS. . . . : cart.localScheda Ethernet Connessione alla rete locale (LAN):
Descrizione . . . . . . . . . . . . . : HP NC105i PCIe Gigabit Server AdapterIndirizzo fisico. . . . . . . . . . . : 00-21-5A-2F-D8-E1
Server DNS . . . . . . . . . . . . . : 127.0.0.1PING from CISCO 3750
Switch>
Switch>en
Switch#ping 10.10.10.1Type escape sequence to abort.
Switch#ping 10.0.0.250Type escape sequence to abort.
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/9 msSwitch#ping 192.168.0.10
10-19-2010 11:38 AM
Switch#
Switch#ping 10.10.10.138
10-19-2010 11:41 AM
No No..you need to use following command on the switch and share output :
/Akhil
