Problem with traffic passing through a vlan at Layer 2
Hi i have a problem with traffic passing through a specific Vlan details below:
The background to this is that traffic in one vlan keeps stopping. The fix for this has been to suspend the vlan (44) in the layer 2 part of the 6500 chassis, but this keeps reoccurring. I am a bit stumped as to why and now the switch has been rebooted and its still occurring.
I have checked the logs and have done a bug scrub and can see nothing that could have caused this issue.
Kev
Re: Problem with traffic passing through a vlan at Layer 2
What is your layer 3 devices config??
Please find the Layer 3 RP config attached.
Kev
Seems to be right, did you try debuging IPX issue?? Is there an IPX server on VLAN 44 that you could monitor your problem??
Check if your IOS version does not have a bug with IPX or some other service you are running, you can check this here:
http://www.cisco.com/cgi-bin/Support/Bugtool/launch_bugtool.pl
Hope this helps
Juan Carlos Arias
133
