Problem with vtp status different version
Hello
I have problem with two switch in vtp is different in thier version one that vtp version 43 and another vtp version 39.
the Two switch have same vtp password. The new vlan in vtp server do not see in vtp client.
TNCat6500Primary#sh vtp status
VTP Version : 2
Configuration Revision : 43
Maximum VLANs supported locally : 1005
Number of existing VLANs : 44
VTP Operating Mode : Server
VTP Domain Name : BBGTO2
VTP Pruning Mode : Enabled
VTP V2 Mode : Enabled
VTP Traps Generation : Disabled
MD5 digest : 0x53 0xB9 0xC9 0x6C 0xF9 0x5F 0xAF 0x21
Configuration last modified by 172.18.9.2 at 2-6-08 22:11:52
Local updater ID is 172.18.9.2 on interface Vl3 (lowest numbered VLAN interface
found)
VTP Version : 2
Configuration Revision : 39
Number of existing VLANs : 42
VTP Operating Mode : Client
VTP Traps Generation : Enabled
MD5 digest : 0xA7 0x03 0x58 0x9C 0x3D 0xFF 0xDC 0xFF
Configuration last modified by 172.18.9.2 at 1-18-08 21:57:35
Cat6500Primary#
can anyone help me?
6 Replies 6
Jon Marshall
Two things
1) Can you send the output of a "sh vtp status"
2) You do have a trunk that is up and running between the 2 switches ?
Also notice VTP Traps Generation is enabled on client but not on server, but i don't know if this would make the difference.
Jon
Jon Marshall
Sorry, not "sh vtp status" but "sh vtp counters"
hello. Thanks for reply. Here the show vtp counters.
TNCat6500Primary#sh vtp counters
VTP statistics:
Summary advertisements received : 254961
Subset advertisements received : 171
Request advertisements received : 20908
Summary advertisements transmitted : 298583
Subset advertisements transmitted : 21105
Request advertisements transmitted : 0
Number of config revision errors : 0
Number of config digest errors : 0
Number of V1 summary errors : 5
VTP pruning statistics:
Trunk Join Transmitted Join Received Summary advts received from
non-pruning-capable device
Gi1/41 573759 574046 0
Gi1/42 572447 572741 0
Gi1/43 572718 573009 0
Gi1/44 897431 897882 0
Gi1/45 882840 883279 0
Gi1/46 1667668 1668488 0
Gi1/47 1783025 1783927 0
Gi3/1 783631 784018 0
Gi3/2 1004064 1004579 0
Gi3/3 1003985 1004489 0
Gi3/4 2304 2304 0
Gi3/5 1601989 1602800 0
Gi3/6 1881976 1882918 0
Gi3/7 868195 868630 0
Gi3/10 897455 0 0
Te2/1 1998020 1999505 0
Te2/3 1998010 1998030 0
TNCat6500Primary#
-------vtp Client------
VTP statistics:
Summary advertisements received : 102714
Subset advertisements received : 51
Summary advertisements transmitted : 82824
Subset advertisements transmitted : 52
Request advertisements transmitted : 19889
Number of V1 summary errors : 0
Te2/1 1999576 1998088 0
Te2/3 2301406 2301235 0
Gi3/3 811874 812139 0
Gi3/10 328138 328109 0
Gi1/4 697625 697586 0
Cat6500Primary#
thanks.
Hey Santiago,
Would this happen to be an extended range VLAN (over 1005) by chance? I've run into that a few times, although it seems like there is definitely an issue with VTP synching in this case due to the fact that the client stopped receiving VTP updates at revision 39 (January 18th).
Maybe you would want to try wiping out the VTP configuration on the Client and rebuilding it? I would also try debugging VTP using 'debug sw-vlan vtp events' on the client to see what the problem is...use the debug at your own risk, but it shouldn't generate too much output.
Hope this helps,
Chris
Hello Chris I end up of recostruir the client I put another domain, return him and I don't work. I also put it in transparent way and he returns him to client and I don't work
I put him again the password and I don't work
Hello Cris I forgot to tell you that also a put debug sw-vlan vtp events' but I don't obtain anything of shown of this debug
