Problematic 6509?
I'm trying to test out some modules on a 6509 but i get a problem on booting with the following display:
System Bootstrap, Version 7.1(1)
Copyright (c) 1994-2001 by cisco Systems, Inc.
c6k_sup2 processor with 262144 Kbytes of main memory
Autoboot executing command: "boot slot0:"
Read cis from dev 0 error (-6)PCMCIA slot0 device is not initialized
open: read error...requested 0x4 bytes, got 0x0
trouble reading device magic number
boot: cannot open "slot0:"
boot: cannot determine first file name on device "slot0:"
this message just keeps looping continuously and i can't even log on.
Also i was trying to do a password recovery (on a 6509 supervisor module) and i managed to bypass the password with the boot bootflash: command, but when i try to replicate this i get no joy - the switch just keeps booting into rommon mode. Any ideas?
Re: Problematic 6509?
Hi there!
I'm no expert on the 6509, but I have done some work on them in the last year; hopefully this is correct.
The line "Read cis from dev 0 error (-6)PCMCIA slot0 device is not initialized" seems significant.
From what I remember, "trouble reading device magic number" means that the OS image may be corrupt; possibly bad checksum?
I would try replacing the PCMCIA memory card with a known good one. Depending on where your 6509 boots the OS image from, you may need to put an image on the PCMCIA card.
Hope this helps!
Kind regards
Graeme
I think you may be onto something there Graeme. I changed over the PCMCIA card to another one (even though the other image was suspect to corruption) and it started to load. The following message came up
*** System received a Software forced crash ***
signal= 0x17, code= 0x41e10000, context= 0x41e355a4
PC = 0x402d146c, Cause = 0x1820, Status Reg = 0x34018002
This image is also corrupted. Where would i get a new image from? How would i upload it? I would presume that this is uploaded from the TFTP server once i get a decent image.
1104
