Problems routing
edgar-quintana
HI,
I attach my configuration.
There is a problem routing in this configuration, is no possible to ping with this attached configuration to 192.168.15x.x machine and 10.21.18.21 machine.
Now, with this configuration I only can ping to 10.21.18.21 machine...
why?
Best regards and thks.
7 Replies 7
Richard Burts
Edgar
I recognize sometimes the need to protect sensitive data. But to post a config about a routing problem in which interfaces are blanked out and ip addresses are hidden is to prevent us from helping you figure out your problem. If we are to be able to help you at all with this issue you must give us reasonable information to work with.
Rick
Rick
Rick Morris
Level 6
Level 6
I agree with Rick, it is hard to know what you have set up with everything important removed. One thing I see is your ip route statement.
Right now you have a default route going to ATM1.1 and there is no metric there.
Then you have a route statment for 192.168.156.0 to go out ATM0.1 with a weight of 200.
Remove the weight.
ip route 192.168.156.0 255.255.255.0 ATM0.1
Then make sure the interface is up/up and that you don't have an acl on the other end blocking ICMP
First... you are right excuse me!!!!!!!!!!
I only post routing parts because I "play" with routes and metrics and worked fine only one no both.
I'll make the changes
Best regards
HI,
Not helpfull...
I'have added static routes as follows:
ip route 192.168.156.0 255.255.255.0 ATM0.1 but
nothing.
what can I do?
Edgar:
Como que usted no entiende lo que te estan pidiendo.
Como putas vamos a poder ayudarte y explicarte cuales son las equivocaciones en el config si has escondido toda la informacion pertinente???
Tenemos que ver todos los IP addresses de todos los interfaces, etc...
Ya basta con esa chingueria, hombre..
Gracias :-)
Victor
paste your config as requested in the first reply. This will help understand what you have in place. You are using private IP's so no worry of security there.
Also provide:
sh ip int brief
traceroutes from both directions
along with the config.
Thomas Tobias
please ignore...just testing.
