11-29-2013 07:33 AM - edited 03-07-2019 04:51 PM
HI all !
End user has a WS-C3560G-48TS-S with c3560-ipbase-mz.122-50.SE5 as switch CORE where intervlan routing is set.
A windows DHCP server with 3 scopes has been configured and is conected to port 8 in switch core.
At the beginning all user and server were in vlan 1 (172.16.30.X) then end user requested to separate network segment;new vlan were set for servers, user, wlans user. In windows DHCP server were defined new scopes for 172.16.33.X, 172.16.35.X
When I try to moved user to 17.16.33. X or 172.16.35.X ( previously the switch port are configured in new vlan)they don´t get
ip address of new segment, some time receive ip address (169.x.x.x) , other times the original segment 172.16.30.X.
just in few times new segments are assigned correctly to ports.
My doubt is,
is there something left in switch's configuracion?
the switch's port where windows DHCP server is connected required an special config?
maybe something wrong in configuration with windows DHCP server (I checked that new scopes are set and active)?
any suggestion for this issue?
thanks in advance for your help
ip routing
interface Vlan300
description SERVER
ip address 172.16.30.30 255.255.255.0
ip helper-address 172.16.30.1
interface Vlan320
description Mgmt
ip address 172.16.32.254 255.255.255.0
interface Vlan330
description Users
ip address 172.16.33.253 255.255.255.0
interface Vlan350
description WLAN_Users
ip address 172.16.35.253 255.255.255.0
interface GigabitEthernet0/8
description SERVER DHCP
switchport mode access
switchport access vlan 300
interface GigabitEthernet0/X
description users
switchport access vlan 330
description users
switchport access vlan 350
11-29-2013 07:39 AM
Providing your DHCP server is 172.16.30.1 then there doesn't seem to be anything obviously wrong with your config. By the way you don't need an ip helper-address on the iinterface for vlan 300 because the DHCP server would see broadcasts from clients in that vlan anyway.
I would be looking at the DHCP server setup.
Edit - i'm assuming the new vlans were created at L2 as well ie. does a "sh vlan brief" show the new vlans ?
Jon
11-29-2013 08:09 AM
Hi Jon,
thanks for your quick response .
All vlans were created and are active ( in this info the new vlans are not associted to the switch's port I shown previously, because a return to vlan 1)
Unfortunately I'm not specialist in windows server so I can't confirm if the config of multiple scopes is wrong or there is somethinng left. I just reviewed general config of the new scopes and that were active.
thanks for you tip for vlan 300
SW#sh vlan brief
VLAN Name Status Ports
300 Servidores active
310 VoIP active
320 Mgmt active
330 Users active
340 Reserva active
350 WLAN_Users active
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
SW#
11-29-2013 08:14 AM
Thanks for the output.
I would pick a test PC, do an "ipconfig /release" on it and then allocate it into the new vlan and try an ipconfig /renew" . There is nothing else that you have configured on the switch that could be confusing the issue is there ?
Jon
11-29-2013 08:17 AM
Hi jon
I really appreciate your time.
We have alredy tried that option and others
ipconfig /release then ipconfig /renew
disconnect the cable
disable the interface and enable once again
reset the PC or lap
any of this works
regards
11-29-2013 08:23 AM
Okay, if you post the config we can check if there is anything there that could be causing the problem.
So you have -
1) ipconfig /release on PC. Check that PC has no IP.
2) on the switch allocate that PCs port into the new vlan
3) check that the L3 inertface for the new vlan is up/up (sh ip int brief | include Vlan)
4) ipconfig /renew on the PC
If you have done in it this order then please ignore.
Jon
11-29-2013 08:45 AM
Hi Filiberto,
I would go back to the servers guys and asked them if they have configured the scopes correctly with correct gateways?
Also, rebooting the server may help too.
11-29-2013 09:00 AM
Hi Reza,
the new scopes includes ip address of default gateways correctly
regards
11-29-2013 08:59 AM
As some one has mentioned that you don't need "ip helper-address 172.16.30.1" under vlan 300, please take this line out. I assume clients are MS windows based then it should be the issue with the DHCP server. Make sure the "DCHP server"service is up and running on the server and proper scope is configured.
11-29-2013 09:04 AM
Hi sajid,
DHCP service is up and running, the original segment is assigned correctly the news ones no
regards
11-29-2013 09:08 AM
When you only had one vlan and scope what was the subnet and subnet mask for that scope ?
Edit - the scopes have been activated haven't they ?
Jon
11-29-2013 09:26 AM
11-29-2013 09:39 AM
If this is still in your config
ip default-gateway 172.16.30.249
can you remove it and add the following and then retest -
no ip default-gateway 172.16.30.249
ip route 0.0.0.0 0.0.0.0 172.16.30.249
Jon
12-01-2013 08:15 PM
Hi Jon
I have already tried static route 0.0.0.0 0.0.0.0 172.16.30.249.
During these days I was looking up in microsoft forum about this issue, I found many cases exactly like this, unfortunately
any of them said if they solved this issue, microsoft specialist state that is a problem from cisco side :-(.
regards
12-02-2013 05:40 AM
Have you done DHCP debugging on the switch when the PC tries to get an address ?
What OS is running on the client PCs ?
Jon
