Having problems with copy tftp flash..
Directory of flash:/
2 -rwx 0 Jan 01 1970 00:01:20 env_vars
3 -rwx 348 Jan 01 1970 00:01:20 system_env_vars
4 -rwx 2206 Mar 01 1993 00:49:54 config.text
5 -rwx 5 Mar 01 1993 00:49:54 private-config.text
6 -rwx 1909 Mar 01 1993 03:55:35 config.old
7 drwx 128 Mar 01 1993 02:30:21 c3550-i9q3l2-mz.121-12c.EA1
15998976 bytes total (14237184 bytes free)
I deleted the ios for upgrading..now I cant copy from my tftp to flash, it works fine on my router just not the switch
CORE_SWITCH#copy tftp flash
Address or name of remote host [192.168.0.3]? 192.168.0.3
Source filename [c3550-ipservicesk9-mz.122-46.SE.bin]? c3550-ipservicesk9-mz.122-46.SE.bin
Destination filename [c3550-ipservicesk9-mz.122-46.SE.bin]?
Accessing tftp://192.168.0.3/c3550-ipservicesk9-mz.122-46.SE.bin...
%Error opening tftp://192.168.0.3/c3550-ipservicesk9-mz.122-46.SE.bin (No such file or directory)
Im using copy and paste for file name so I know that is correct and can ping 192.168.0.3 from swtich
Building configuration...
Current configuration : 2267 bytes
version 12.1
no service single-slot-reload-enable
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname CORE_SWITCH
enable secret 5 $1$q29c$bftYUVGCw/8Bij/WV0a0c1
ip subnet-zero
no ip domain-lookup
interface FastEthernet0/1
no ip address
interface FastEthernet0/2
no ip address
interface FastEthernet0/3
no ip address
interface FastEthernet0/4
no ip address
interface FastEthernet0/5
description 1ST CONNECTION TO SWITCH 2
no ip address
interface FastEthernet0/6
description 2ND CONNECTION TO SWITCH 2
no ip address
interface FastEthernet0/7
description 1ST CONNECTION TO SWITCH 1
no ip address
interface FastEthernet0/8
description 2ND CONNECTION TO SWITCH 1
no ip address
interface FastEthernet0/9
no ip address
interface FastEthernet0/10
no ip address
interface FastEthernet0/11
no ip address
interface FastEthernet0/12
no ip address
interface FastEthernet0/13
no ip address
interface FastEthernet0/14
no ip address
interface FastEthernet0/15
no ip address
interface FastEthernet0/16
no ip address
interface FastEthernet0/17
no ip address
interface FastEthernet0/18
no ip address
interface FastEthernet0/19
no ip address
interface FastEthernet0/20
no ip address
interface FastEthernet0/21
no ip address
interface FastEthernet0/22
no ip address
interface FastEthernet0/23
no ip address
interface FastEthernet0/24
description CONNECTION TO CORE ROUTER
no ip address
duplex full
speed 100
interface GigabitEthernet0/1
no ip address
interface GigabitEthernet0/2
no ip address
interface Vlan1
description MANAGEMENT INTERFACE
ip address 192.168.10.19 255.255.255.0
ip default-gateway 192.168.10.1
ip classless
ip http server
banner motd ^CCCCC
###DO NOT LOG ON AUTHORIZED PERSONNEL ONLY####
^C
alias exec s show ip interface brief
alias exec rc show running-config
alias exec r show ip route
alias exec v show version
line con 0
exec-timeout 30 0
password 7 14141B180F0B
logging synchronous
login
line vty 0 4
exec-timeout 30 0
password 7 01100F175804
logging synchronous
login
line vty 5 15
login
end
