problems with IOS in redundant sup720 into cat 6509e
when new sup 720 installed initally went to rommon, then did a boot from the console, came up as standby cold,
the standby is running (s72033_rp-IPSERVICESK9-VM), Version 12.2(18)SXF7
but I cannot find where that code is
doing a DIR ALL does not show it anywhere
copied the running code to the slavebootflash:
changed the boot statements in the config to boot from the bootflash, did a copy running start and the config went acorss to the standby 720 ok, did a redundancy reload peer command, to reload the standby 720, but still came up running the (s72033_rp-IPSERVICESK9-VM), Version 12.2(18)SXF7 code instead of the SXD5 code.
where is the s72033_rp-IPSERVICESK9-VM), Version 12.2(18)SXF7 code??
see enclosed output of
show redundancy and dir all commands
Re: problems with IOS in redundant sup720 into cat 6509e
Is the active supervisor running this image 12.2(18)SXF7. Can you post the output of 'dir all' from the active SE?
the dir all is in the attachment with the orig post
the active SE is running 122-18.SXD5
You seem to have done everything the correct way.
Can you try resetting the module 'reset 6' to reload the standby SE rather than using the 'redundancy reload peer' command?
Sundar
I just noticed this in your first posting "went acorss to the standby 720 ok, did a redundancy reload peer command, to reload the standby 720,".
To reload the standby (slot 6) you would have the issue command 'redundancy reload peer' from the active SE (slot 5). You can either do that or do 'reset 6' from the active SE.
Sundar
ok so there is no difference between
the "Redundancy reload peer" and the "hw-module module 6 reset" commands
I am still puzzled where it gets the 122(18)SXF code from, I tell the machine to load from bootflash with the boot cmmand but still loads this SXF code from?
Where did you issue the 'redundancy reload peer' command from? Your original post indicates you did that from the standby SE. If that's true then you would have reset the active SE and not standby SE. Can you try either issuing the command 'redundancy' command from the active SE in slot5 or 'reset 6'.
Sundar
All I was saying that the config went across to the standby, I am using the active SE, console is not active on the standby. so I am always reloading the new Sup720 in slot 6
Can you post the console output of standby SE when it was reloading?
see below for part of console output
it says bootflash: is an invalid device!
System Bo otstrap, Version 8.4(2) Release
Copyright (c) 19 94-20 05 by cisco Systems, Inc.
Cat6k-Sup720/SP processor with 524288 Kbytes of main memory
Autoboot executing command: "boot bootflash:s72033-psv-mz.122-18.SXD5.bin"
Loading image, please wait ...
Invalid device specified
Booting from default device
Initializing ATA monitor library...
string is bootdisk:s72033-ipservicesk9-vz.122-18.SXF7.bin
Self extracting the image... [OK]
Self decompressing the image : #################################### [OK]
running startup....
bootflash: bf_io_devctl: DEVCTL error 19
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) s72033_sp Software (s72033_sp-IPSERVICESK9-VM), Version 12.2(18)SXF7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Thu 23-Nov-06 09:24 by kellythw
Image text-base: 0x01020150, data-base: 0x01021000
Community Member
I think you might have a problem in your boot config. Because the directory of the ios you want to use is in the sup-bootflash:/ instead of bootflash:
Directory of sup-bootflash:/
1 -rw- 45465300 Jul 6 2005 13:36:17 +10:00 s72033-psv-mz.122-18.SXD5.
pointing the boot coomand to 'sup-bootflash' made no difference, still goe to the default.
I have ordered some compact flash, hopefully installing these and pointing to boot from disk0 will cure the problem,
I am still mysterfied why I cannot see the default ATA when I do a dir all command
1115
