01-14-2009 10:14 AM - edited 03-06-2019 03:26 AM
CEF is enabled on the interface yet I only see processor packet counts below and not route cache. Please explain why is that.
SWITCH#sh int stats
GigabitEthernet4/1
Switching path Pkts In Chars In Pkts Out Chars Out
Processor 0 0 45516 21001468
Route cache 0 0 0 0
Distributed cache 0 0 0 0
Total 0 0 45516 21001468
01-14-2009 10:36 AM
The prompt indicates that this is a switch. Switches use ASICs and do much of the forwarding in hardware. The packets that are switched in hardware do not show up in the interface stats.
Rick
01-14-2009 10:40 AM
It is a CAT6500 switch and ip cef is enabled on all the interfaces.
Wouldn't route cache be considered as hardware switched. And what does processor count in the given output mean.
Thanks.
01-14-2009 10:49 AM
no route cache (nor CEF) is not considered hardware switching. hardware switching is when the ASIC on the switch makes the forwarding decision.
Rick
01-14-2009 10:51 AM
Route cache is associated with fast switching which is not CEF. 6500 don't use fast-switching.
Processor would be the Route Processor ie. the vast majority of packets are hardware switched on a 6500 using the PFC (Policy Feature Card). Those that can't be hardware switched are sent to the processor (MSFC) to be dealt with by the main CPU.
Jon
01-14-2009 10:56 AM
Please explain the below statement on
Quote
e. Issue the show interface stats command and confirm incremental hits for route cache inbound.
Note: The route cache counter includes both fast-switched and CEF-switched packets.
Unquote
01-14-2009 11:16 AM
That article was written from the perspective of IOS "routers". In particular remember this note from the beginning of the article:"Note: This document discusses process switching, fast switching, and Cisco Express Forwarding (CEF) only." It explicitly indicates that it does not discuss hardware switching (on Catalyst switches).
Within its frame of reference the article is correct and helpful. But your question is an aspect that is outside the scope of the article.
Rick
01-14-2009 11:20 AM
Can you post output of
"show interfaces gigabitethernet 4/1 | include Switched"
Jon
01-14-2009 11:30 AM
The output is none.
01-14-2009 11:31 AM
What IOS version are you running on the 6500 ?
Jon
01-14-2009 11:37 AM
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Versio
n 12.2(33)SXH3, RELEASE SOFTWARE (fc1)
01-14-2009 11:49 AM
Okay, can you just post output of
sh interface gi4/1
Jon
01-14-2009 11:55 AM
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseT
input flow-control is off, output flow-control is on
Clock mode is auto
Last input never, output 00:00:32, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 119450
Queueing strategy: fifo
Output queue: 0/40 (size/max)
16364141 packets input, 19262818975 bytes, 0 no buffer
Received 2669 broadcasts (2 multicasts)
0 watchdog, 0 multicast, 0 pause input
29693021342 packets output, 2671695433517 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
01-14-2009 12:12 PM
Okay, apologies not what i was expecting.
Please see the command reference for 12.2SX for the command "sh interface stats". Note that it only talks about process and fast switched packets not CEF switched.
Your link has made me have another search through the docs so i'll keep looking :-)
Jon
01-14-2009 12:21 PM
Shifting to another query..
I am experiencing giants on 'show interfaces counters errors'. The MTU set on the server is 9000 and Cat6500 interface has been enabled for 9216. I don't see any CRC or FCS errors but the giants. The application using the interface has not complained as yet. Could you please let me know why would the giants appear in such way. I thought it would always be accompanied by FCS errors.
