Processor Memory C2960
DPlagueHT
Hello
I have a C2960-24PC-L which has a very high occupancy of the processor memory. I've used version 15.0SE 15.0SE2 and now 15.0SE3 and the problem seems to persist.
                Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b)
Processor    25D93F0    23726640    18936520     4790120     4625036     4638188
      I/O    2C00000     4194304     2581800     1612504     1286940     1287256
Driver te    1800000     1048576          44     1048532     1048532     1048532
Dead Proc Summary for: Processor
    PC          Total   Count  Name
0x00535E00     821804      41  mifs NOR Sector
0x000196E0      32488     258  hulc_flash init
0x0053A73C      25220       5  mifs sector buf
0x005364DC      20044       1  mifs NOR Sector Info Pointers
0x00536504      20044       1  mifs NOR Sector Info Pointers
0x0053BD90      10088       2  mifs sector buffers
Allocator PC Summary for: Processor
    PC          Total   Count  Name
0x0142EB94    2310848     292  Process Stack
0x002E231C    1417268    1226  *Packet Header*
0x00E304BC     712840       8  Init
0x013A70F8     545460      39  TW Buckets
0x00426854     439340       1  Init
0x012C4248     393480       6  STP Port Control Block Chunk
0x012CC824     360660    4094  STP Config Block
0x00EB8980     295332    3161  IPC Thread Slot
0x012CCB14     280148    4094  STP Port Tree Config Block
0x002E563C     262720       6  pak subblock chunk
0x00904AF4     262304       1  RE Message Chunk
0x009571E0     262232       2  CEF: hash table
0x00426830     256300       1  Init
0x002E236C     230376       5  *Packet Data*
0x013EA934     219240     290  Process
Is there anything I can do to lower the memory consumption?
Thanks for the help
5 Replies 5
David Santos
Green,
can you please show "sh run proc cpu sorted"
DS
of course
PID  Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
131      902965     5931514        152  0.15%  0.28%  0.37%   0 Hulc LED Process
132        8920      173812         51  0.15%  0.01%  0.00%   0 HL3U bkgrd proce
197      321212     1373797        233  0.15%  0.10%  0.11%   0 Spanning Tree
147      136251      235751        577  0.15%  0.05%  0.05%   0 PI MATM Aging Pr
   5          85        3961         21  0.00%  0.00%  0.00%   0 Pool Manager
   6           0           1          0  0.00%  0.00%  0.00%   0 DiscardQ Backgro
   4      401730       42599       9430  0.00%  0.11%  0.11%   0 Check heaps
   8           9         180         50  0.00%  0.00%  0.00%   0 WATCH_AFS
   9           0           1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
   3          18        2046          8  0.00%  0.00%  0.00%   0 DHCPD Timer
   7           0           2          0  0.00%  0.00%  0.00%   0 Timers
  12        2145        7456        287  0.00%  0.00%  0.00%   0 ARP Input
   2         214       47522          4  0.00%  0.00%  0.00%   0 Load Meter
  14           0           1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  15           0           1          0  0.00%  0.00%  0.00%   0 Policy Manager
  16           8           5       1600  0.00%  0.00%  0.00%   0 Entity MIB API
  17           0           1          0  0.00%  0.00%  0.00%   0 IFS Agent Manage
  10           0           1          0  0.00%  0.00%  0.00%   0 Crash writer
  11           0           1          0  0.00%  0.00%  0.00%   0 Exception contro
  13        1222      246629          4  0.00%  0.00%  0.00%   0 ARP Background
  21           0           1          0  0.00%  0.00%  0.00%   0 IPC Session Serv
  22           0           1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  23         519      230885          2  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  24         867      230885          3  0.00%  0.00%  0.00%   0 IPC Deferred Por
  18          32       47451          0  0.00%  0.00%  0.00%   0 IPC Event Notifi
  26           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat Manager
  27          16       13574          1  0.00%  0.00%  0.00%   0 IPC Check Queue
  28           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat RX Cont
  29           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat TX Cont
  30          52       23765          2  0.00%  0.00%  0.00%   0 IPC Keep Alive M
  31           0       47452          0  0.00%  0.00%  0.00%   0 IPC Loadometer
  32          84           5      16800  0.00%  0.00%  0.00%   0 PrstVbl
  33           8           2       4000  0.00%  0.00%  0.00%   0 XML Proxy Client
Leo Laohoo
I believe that's a cosmetic bug.
capture sh cpu processes and see which interface is utilising the more cpu utilization.
You can check the machjine/server connected to that interface.
1st step try shutting the suspect interafce and check if the process utilzation gets down and works normally....
I put the "sh processes cpu" above.
No interface have relevant traffic at this time, for example, the uplink:
5 minute input rate 80000 bits / sec, 21 packets / sec
5 minute output rate 11000 bits / sec, 8 packets / sec
thanks
