04-20-2010 05:41 PM - edited 03-06-2019 10:42 AM
Hi every body.
I was little confused about the usage of " pseudo header" in udp. Below is the link which explains the use of " pseudo header" in udp.
http://http://www.tcpipguide.com/free/t_UDPMessageFormat-2.htm
against it?
I am still at loss as to what purpose this header serves. According to the link,this " pseuo header protects against the accidental delivery of message to wrong destination.
The question is how could a message end up at wrong destination? how does pseudo header protect against it?
thanks and have a great day.
Solved! Go to Solution.
04-21-2010 12:53 AM
sarahr202 wrote:
Hi every body.
against it?
Sarah
UDP is fire and forget ie. there is no acknowledgement from the receiving machine that it has received the packet and there is no initial connection setup as you get with TCP. When the protocol was originally designed one of the concerns was that the packet could actually end up at the wrong destination ie. it only takes a bit to be flipped by an intermediate device for this to happen. TCP has inbuilt checks because of the 3 way handshake etc. but UDP does not.
So the pseudo header was used. By including the IP addresses/port numbers in the checksum only the correct receiving host would have the same combination of IP addresses and port numbers and so could compute the same checksum. If the checksum was incorrect then the receiving host would simply drop the packet.
Jon
04-21-2010 12:53 AM
sarahr202 wrote:
Hi every body.
against it?
Sarah
Jon
04-21-2010 03:07 AM
thanks Jon.
