01-27-2014 09:34 PM - edited 03-07-2019 05:50 PM
All of a sudden PT crashed and prompted me to save the dump file, do anyone know how to recover my topology from .dmp file?
Thanks in advance.
Chandu
01-27-2014 10:39 PM
Here is the screenshot.
Chandu
01-28-2014 01:57 AM
Looking at the screenshot you posted above, it suggests the .dmp is a diagnostic file which will allow someone with knowledge to find out why PT crashed. It makes no mention of the actual topology being saved into or with the .dmp file.
I would suggest that unless you saved the topology, you will have to recreate it.
07-31-2023 12:18 AM
I have the same issue, I've already recreate it, even on another PC. The issue occurs when i want to open the pc and the laptops to check if the configuration of the dhcp has worked. And now it's even worse because when i open a new PT project, when i create an end device (PCs, Laptops,...), and i click on it, the error's message pop up.
