Public IP Routing
I am trying to install 4 cameras with static ip and routing to a single STATIC PUBLIC IP.
Need an advise which router model should I consider to do the task.
Re: Public IP Routing
You can use Cisco 800 series routers, according to your WAN technology required.
The Cisco 800 Series broadband access routers come standard with 4-port 10/100 Mbps managed switch:
http://www.cisco.com/en/US/products/hw/routers/ps380/prod_models_comparison.html
HTH, please rate if it does help,
Mohammed Mahmoud.
I am not really sure if the idea I have in mind is the same as the specification and information provided by cisco 851 router. Need your further advise. The setup should be:
1 WAN IP routing to 4 static private IP.
Any router from the 800 series shall do the job for you, but you'll need to get back to your provider to know the WAN Interface that he supports, plus you have to consider do you want the 802.11b/g wireless (available only for 851, 857, 871, 876 and 878) or not (805, 828, 831, 836 and 837).
Mohammed Mahmoud.
Basically what are the basic and standard WAN interface is using by providers? As of the moment wireless connection is not yet in the plan.
Also, I will ask my providers what WAN interface that they support.
The most common WAN technologies are ADSL and G.SHDSL.
Contact your provider, and good luck.
Mohammed Mahmoud.
156
