06-06-2007 12:59 AM - edited 03-05-2019 04:30 PM
Hi all, when setting up my 1200 series ap, do I put the ip address both on the fast ethernet interface and the BVI interface, or do I put no ip on the fast ethernet and just put one on the BVI and use the bridge-group command ?
please help
06-06-2007 01:25 AM
Only on the BVI to the management.
There is a implicit bridge group if you use the vlan 1.
If you would like to make VLANs, it's little different in the way of the non tagged you want.
Ludo
06-06-2007 04:08 AM
does it automatically bridge between the radio and fast ethernet interfaces ?
06-06-2007 04:29 AM
yes
06-06-2007 10:54 PM
can you give me an example of this ?
