pvlan connecting to an upstream switch
folks
i have a query re pvlans connecting to an upstream switch
i currently have a firewall connecting to a switch (switch A) on a promiscuous port (PVLAN 16)
the switch has another switch (switch B) chained off it on a trunk port
i now have a requirement to introduce a new 'core' switch between the firewall and switch A
the reason is to use this core switch to terminate other firewall dmzs so we can cut down on switch intrastructure
the core switch will now terminate switches that carry other pvlans (18 & 20) but isn't configured with any pvlans
each pvlan has its own set of downstream switches and will connect to different firewall interfaces (no subinterfaces) via the core switch
i tried to configure this last week in a short maintenance window but couldn't get it working
i set up the core switch with a trunk port to switch A (also a trunk) and from the firewall could ping switch A & B but not the hosts
my query
do i need to keep the ports between the core switch and downstream pvlan switches (ie switch A) as promiscuous
as the core doesn't have any pvlan configuration the links to the various firewall interfaces are configured as access ports for the particular vlan
thanks to anyone taking the time to read this or to comment and apologies for the convoluted description
Everyone's tags (1)
1 REPLY
folks
anyone any ideas?
163
