PVLANs and firewalls
folks
i have a switch setup with a primary pvlan, a host vlan and a community vlan
i've been asked to allow two hosts, host A & host B, to have limited connectivity to each other (SQL & SMB traffic only)
i had created a community but it now seems there are other hosts which will need to speak to host A so i have a bit of a dilemma
as i can see it i'll have to
- set up Host A as a promiscuous port but that will allow all devices on all ports in that ip range to speak to it
- move host A to another DMZ out of the pvlan
above the switch is a juniper firewall
thanks to anyone taking the time to reply or to read this, much appreciated
1 REPLY
Re: PVLANs and firewalls
Hi ,
In my opinion moving the host A in a diferent DMZ would be the best solution.
Now the solution depends on the security rules on your company and how secured do you want your access to services, in their absence.
Dan
176
