08-23-2012 04:50 AM - edited 03-07-2019 08:30 AM
I have a new cisco 1941 router that I am setting up with pxebooting. I have never setup pxebooting before and i have this setup so far
ip dhcp pool Admin
option 66 ip 192.168.1.4
option 67 ascii pxelinux.0
and i can pull an ip but it keeps getting hung up when it comes to the TFTP part.,
Any help would be much appreciated.
Thanks in advance
08-23-2012 05:01 AM
Did you check the option 150?
I think you need it to contact another server as a tftp server.
Alessio
08-23-2012 05:09 AM
So make it redundant and set option 150 to the tftp server ip which is 192.168.1.4?
Thanks for the quick response.
08-23-2012 05:57 PM
So i figured it out here are the commands to get it to work
ip dhcp pool Admin
network 192.168.1.0 255.255.255.0
bootfile pxelinux.0
next-server 192.168.1.4
default-router 192.168.1.1
dns-server 8.8.8.8
option 150 ip 192.168.1.4
lease 1 23 59
08-23-2012 06:21 PM
So rate my post if that helped you
