Community Member
PxeBoot Help with DHCP
I have a new cisco 1941 router that I am setting up with pxebooting. I have never setup pxebooting before and i have this setup so far
ip dhcp pool Admin
option 66 ip 192.168.1.4
option 67 ascii pxelinux.0
and i can pull an ip but it keeps getting hung up when it comes to the TFTP part.,
Any help would be much appreciated.
Thanks in advance
Did you check the option 150?
I think you need it to contact another server as a tftp server.
Alessio
Community Member
So make it redundant and set option 150 to the tftp server ip which is 192.168.1.4?
Thanks for the quick response.
Community Member
So i figured it out here are the commands to get it to work
ip dhcp pool Admin
network 192.168.1.0 255.255.255.0
bootfile pxelinux.0
next-server 192.168.1.4
default-router 192.168.1.1
dns-server 8.8.8.8
option 150 ip 192.168.1.4
lease 1 23 59
Re: PxeBoot Help with DHCP
So rate my post if that helped you
830
