Q-in-Q tunnelling
Is it possible to create Q-in-Q tunnel in cisco 2921 and 2911 ISR without using a Ether switch module in these devices ?
Thanks & Regards,
Rahul Chhabra
Hello Rahul , No , This
Hello Rahul ,
No , This feature is supported on EtherSwitch service module , but not on the hosting routers .
Sunil Bhadauria
 Thanks for Replying Sunil
could you please tell me what do you mean by 'but not on the Hosting routers'
Thanks & Regards,
Rahul Chhabra
Network Engineer
Spooster IT Services
Hello Rahul , by hosting
Hello Rahul ,
by hosting router i mean the ISR router where the module is installed .
Sunil Bhadauria
 Thanks once again for
Thanks once again for helping me
YW , Just to add ,
YW ,
Just to add , etherswitch service module run  its own independent software then hosting router to provide additional features, and q-in-q tunneling is one of them .
Have a nice day ahead .
Sunil Bhadauria
 Hi Sunil,I want to know
Hi Sunil,
I want to know something more about the Q-in-Q tunnel on Cisco 2921 ISR.
1. Could you please provide me a sample config with a small design of         creating a Q-in-Q tunnel.
2. Can you provide me any documentation to read about this feature.
3. Is their any other method or command to achieve this task without using
    a ether switch module on the ISR 2921.
Thanks & Regards,
Rahul Chhabra
Network Engineer
Hello Rahul , As far as I see
Hello Rahul ,
As far as I see , dot1q tunneling is not possible on 2900 without etherswitch services module .
You will get most of your answers in below documentation :
http://www.cisco.com/c/en/us/products/collateral/routers/2800-series-integrated-services-routers-isr/prod_qas0900aecd8028d16a.html
Configuration guide :
I do not see any documentation for 2900 platforms ( may be because they natively do not support it ) , but only additional command for dot1q tunnel funtionality needed is :
"switch-port mode dot1q-tunnel " on CE facing access port .
you may refer below documentation for configuration guide/example :
http://www.cisco.com/c/en/us/td/docs/switches/metro/me3400e/software/release/12-2_55_se/configuration/guide/ME3400e_scg/swtunnel.pdf
-Other then dot1q tunneling another way to achieve q-in-q is vlan stacking . I never used this feature myself and do not have 2900 platform handly to test on it yet , but you can try below configuration to achieve it :
(apply similar configuration on other end accordingly )
# Interface gi0/0
No ip address
#Int gig 0/0.20
Encapsulation dot1q 10 second 20
Ip address 10.0.20.1 255.255.255.0
Int gig 0/0.30
Encapsulation dot1q 10 second 30
ip address 10.0.30.1 255.255.255.0
So in above configuration vlan 10 is outer vlan id which will be used to transport customer traffic through service provider environment untill far end PE router ( where similar set of configuration will ensure inner vlan id 20/30 to send traffic towards CE device ) .
You may refer below documentation for this feature and prerequisites :
http://www.cisco.com/en/US/docs/ios/lanswitch/configuration/guide/lsw_ieee_802.1q.html
Sunil Bhadauria
 Thanks sunil for providing
Thanks sunil for providing answers
Rahul
549
