QinQ tunneling
Hi everybody,
I am confused with QinQ Tunneling in 3560 Switch. Please find the attached diagram.
I need clarity where to configure Trunk and where to configure Tunnel.
Please explain
1. Whether Switch D port Fa0/1 has to be configured as "switchport mode tunne" or "switchmode mode trunk"
2. Whether Switch A port Fa0/2 has to be configured as "switchport mode tunnel" or "switchmode mode trunk"
3. Whether Switch B port Fa0/3 has to be configured as "switchport mode tunnel" or "switchmode mode trunk"
Please help me in advicing how to go with and answer the above questions
Thanks in advance
RBK
Re: QinQ tunneling
Kumar,
First of all, ISP devices don't about vlan 100,101,103. Assuming that I want to user Vlan 1000 for tunneling in ISP. Okay you may know how QinQ works for us.
- SwitchD f0/1 and SwitchE f0/7 are TRUNK.
- SwitchA,SwitchB,SwitchC have Vlan1000 in vlan DB. All interfaces connecting between them are TRUNK.
- SwitchA f0/0 and SwitchC f0/6 configured as follows:
SwitchA(config)# interface gigabitethernet0/0
SwitchA(config-if)# switchport access vlan 1000
SwitchA(config-if)# switchport mode dot1q-tunnel
SwitchC(config)# interface gigabitethernet0/6
SwitchC(config-if)# switchport access vlan 1000
SwitchC(config-if)# switchport mode dot1q-tunnel
Let's test connection between vlan100,101,103. It should work I thought!!(grin)
HTH,
Toshi
Hall of Fame Super Silver
Re: QinQ tunneling
Hello R.B. Kumar,
the command switcport mode tunnel is needed on the SP equipment and only on port facing customer equipment
in your case
SwitchA :f0/0 and SwitchC:f0/6
they need to share the same access vlan = customer vlan to build a point-to-point service.
that vlan has to be permitted on trunk ports in Switch A,B,C.
all other ports including SP ports should be trunk ports.
Hope to help
Giuseppe
621
