Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
QoS 6509\3548XL
hi all,
I have a 6509 running SUP1A\MFC2 & Access Switches 3548XL
I am look to enable QoS on specific ports on these switches.
For the 6509
I have a trust setup below on the uplinks
set qos acl ip acl_1 trust-dscp ip 172.x.0.0 0.0.255.255 172.x.0.0 0.0.255.255 dscp-field 46
I have a 10/100 blade. Is it possible to configure these ports as trusted ports?
For the 3548
Which is the better cmd to use
switchport priority extend cos 5 switchport priority extend trust
Is there any further cmd that I need on the 3548 to enable QoS?
Thanks in advance
1 REPLY
Silver
Re: QoS 6509\3548XL
I think mls qos command is use for Enable QoS for the entire switch. And also enter the tunnel tos command, if present, to set the ToS byte of a packet when it is encapsulated. If the tunnel tos command is not present and you do not enable QoS, the ToS byte of a packet sets the ToS byte of the packet when it is encapsulated. If the tunnel tos command is not present and you enable QoS, the ToS byte of a packet as modified by PFC QoS sets the ToS byte of the packet when it is encapsulated.
312
