04-29-2012 12:38 AM - edited 03-07-2019 06:24 AM
Dear Gents,
We are planing to implement Qos in our environment and there is some issue which is related to DSCP markings.
Currently we have some applications which cannot mark the traffic and i am planning to use ACL to mark them.Below is the sample.
ip access-list exteneded qosmark
permit ip host 10.1.120.50 any
class-map qosclass
match access-group qosmark
policy-map mark
class qosmark
set dscp af21
interface ten1/4
service-policy mark output
I am confused and want to clarify whether all my other traffic which is not specified in the access-list will be denied or it will flow without being marked.
I am concerned here because there is explicit deny at the end of acl.
04-29-2012 01:28 AM
If you configured it as you propose, you would see something like this:
R1#sh policy-map int fa0/0
FastEthernet0/0
Service-policy output: mark
Class-map: class-default (match-any)
7 packets, 1293 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: any
A default class is implicitly added to your policy map and all other traffic is forwarded via it.
regards,
Leo
04-29-2012 03:29 AM
Thanks for your reply.
So you mean that there is no need for permit ip any any under the ACL..?.and all other traffic will forwarded without being marked and denied.
Please confrim.
04-29-2012 03:44 AM
The traffic that is not matched by the policy-map will not be droped and will not have the DSCP modified by this equipment - because it could be marked when arrives at this point ( teoretically ).
You can use your posted configuration without any fear.
Dan
04-29-2012 03:45 AM
Please confrim.
Yes.
