Community Member
QOS configured on SIP-400 with bridge-domain
Dear all,
i am setup a lab the test the QOS on bridge-domain and configure and sample output as below:
I found the QoS is not work, can anyone help me
class-map match-all IAS_AFCD
match access-group name IAS_AFCD
policy-map IAG_QOS
class IAS_AFCD
shape average 1024000
policy-map QOS
class class-default
shape average 3000000
service-policy IAG_QOS
interface GigabitEthernet4/0/0
ip vrf forwarding IAGS_GNET_In
ip address 10.106.243.90 255.255.255.248
load-interval 30
negotiation auto
no snmp trap link-status
service-policy output QOS
interface GigabitEthernet4/0/1
no ip address
load-interval 30
negotiation auto
interface GigabitEthernet4/0/1.1622
encapsulation dot1Q 1622
bridge-domain 1622 dot1q
interface Vlan1622
ip address 10.106.233.172 255.255.255.248
ip access-list extended IAS_AFCD
permit ip host 10.106.103.41 host 10.1.106.51
permit ip host 10.1.106.51 host 10.106.103.41
sample output
sh policy-map interface g4/0/0
class-map: IAS_AFCD (match-all)
1810772 packets, 1336347432 bytes
30 second offered rate 5997000 bps, drop rate 4806000 bps
Match: access-group name IAS_AFCD
Queueing
queue limit 256 packets
(queue depth/total drops/no-buffer drops) 257/1428308/0
(pkts output/bytes output) 263782/198845964
shape (average) cir 1024000, bc 4096, be 4096
target shape rate 1024000
sh policay-map interface 4/0/1.1622
Class-map: IAS_AFCD (match-all)
0 packets, 0 bytes
30 second offered rate 0 bps, drop rate 0 bps
Queueing
(queue depth/total drops/no-buffer drops) 0/0/0
(pkts output/bytes output) 0/0
1 REPLY
Hall of Fame Super Silver
Re: QOS configured on SIP-400 with bridge-domain
Hello Ng,
two notes:
the bridge-domain is a command that allows bridging between Giga subifs
http://www.cisco.com/en/US/docs/ios/lanswitch/command/reference/lsw_b1.html#wp1017027
in your configuration I don't see the second subif in the bridge (at least a second one to bridge)
in addition all examples show they use different values for the enc dot1q and the bridge-domain command
see the following example
Router(config)# vlan 100
Router(config-vlan)# exit
Router(config)# interface GigabitEthernet 1/0/1.1
Router(config-subif)# encapsulation dot1q 10
Router(config-subif)# bridge-domain 100 dot1q
Router(config-subif)# exit
Router(config)# interface GigabitEthernet 1/0/2.1
Router(config-subif)# encapsulation dot1q 20
This could explain why the QoS never matches no traffic is going through the bridge being the bridge single-arm.
Hope to help
Giuseppe
214
