QoS: Different police format, different output
I've noticed drastically different output with the "show policy-map" command
depending on which format of the "police" command I use. The main difference
appears to be whether I use the "cir" keyword or not. Here is the class-map
and policy-map config that I used:
class-map match-all test_map
match vlan 100
policy-map test1
class test_map
police cir 100000 bc 8000
policy-map test2
class test_map
police 100000 8000 exceed-action drop
Output of "show policy-map"
Policy Map test2
Class test_map
police 96000 8000 exceed-action drop
Policy Map test1
Class test_map
Police cir 96000 bc 8000
conform-action transmit
exceed-action drop
violate-action drop
Output of "show policy-map interface" with test 1 active:
GigabitEthernet1/1/2
Service-policy output: test1
Class-map: test_map (match-all)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: vlan 100
police:
cir 96000 bps, bc 8000 bytes
pir 96000 bps, be 8000 bytes
conformed 0 packets, 0 bytes;
exceeded 0 packets, 0 bytes;
exceed-action drop
violated 0 packets, 0 bytes;
violate-action drop
conformed 0 bps, exceed 0 bps violate 0 bps
Class-map: class-default (match-any)
0 packets, 0 bytes
Match: any
Output of "show policy-map interface" with test 2 active:
Service-policy output: test2
0 packets, 0 bytes
Match: vlan 100
0 packets, 0 bytes
Match: any
Notice how the output when test1 is invovled is much more detailed
and explicitly lists the policing information. Is this just aesthetic,
or is test2 actually not performing any policing? The swtich is a 3750
running IOS Version 12.2(25)SEG1.
I'm thinking it may have something to do with whether a single rate policer
is being used or a dual rate policer, though I don't know why test1
would use a fual rate policer because I don't list a pir or violate action.
144
