QoS/DSCP marking on a 3750G-EMI
Sorry to ask the stupid question, but I can't figure this out. I am running a converged LAN supporting about 1500 devices (1000 computers, 500 phones). I am running two 3750G-24TS switches (running 12.2(35)SE2) at Layer 3 as my core. They support all my voice and data SVIs. My routers on my WAN edge use DSCP markings for QoS on my outbound links.
I'm trying to move the DSCP marking off the routers and on to the multi-layer switches. I have the ACLs, class-maps, and policy-maps defined on the switch. IP CEF is enabled. I did remember to issue the global "mls qos" command. I did remember to attach the service-policy input on the interface I'm testing with. "Show mls qos" shows QoS enabled, and ip packet dscp rewrite enabled. "show mls qos interface g1/0/27" shows the correct policy-map attached to the interface, but shows 0 packets offered and the ACLs show 0 packets matched. I have tried attaching the service-policy on both the physical interfaces and on the SVIs. The only thing I'm trying to do on the 3750Gs right now is classify and mark -- I'm letting the routers use WRED to drop excess traffic. Any ideas why I'm not getting any matches? I'm guessing I missed a global command somewhere, but for the life of me, I can't figure it out.
Right now, I'm stuck doing the classification and DSCP marking on the ingress interfaces of the routers (3725s), and WRED on the egress interfaces. That works fine, so I think I've got the basic concepts down. Any thoughts?
Hall of Fame Super Bronze
Re: QoS/DSCP marking on a 3750G-EMI
Can you post the relevant portion of the config ?
Sure:
ip cef
mls qos
class-map match-all BulkData
match ip dscp default
class-map match-all VoiceSig
match ip dscp cs3
class-map match-all NetworkControl
match ip dscp cs6
class-map match-all CriticalServers
match access-group name CriticalServers
class-map match-all VoIP
match ip dscp ef
class-map match-all Video
match access-group name Video
policy-map DataMark
class CriticalServers
set dscp af31
class Video
set dscp af32
class BulkData
set dscp af23
interface GigabitEthernet1/0/27
description -> Distro4
switchport mode trunk
service-policy input DataMark
ip access-list extended CriticalServers
remark Collaboration Server
permit ip host x.x.x.x any
permit ip any host x.x.x.x
remark Transaction Server
permit ip host y.y.y.y any
permit ip any host y.y.y.y
ip access-list extended Video
permit ip z.z.z.z 0.0.0.15 any
permit ip any z.z.z.z 0.0.0.15
CORE1# show policy-map interface g1/0/27
Class-map: CriticialServers (match-all)
0 packets, 0 bytes
offered rate 0 bps, drop rate 0 bps
Match: access-group name CriticalServers
0 packets, 0 bytes
rate 0 bps
Class-map: Video (match-all)
0 packets, 0 bytes
Match: access-group name Video
Class-map: BulkData (match-all)
0 packets, 0 bytes
Match: ip dscp default(0)
0 packets, 0 bytes
rate 0 bps
Class-map: class-default (match-any)
0 packets, 0 bytes
Match: any
0 packets, 0 bytes
rate 0 bps
CORE1#
Thanks!! I know some of the choices for DSCP marking look odd, but they fit
our enterprise DiffServ model well at the WAN linkages. I'm just trying to figure out why my CORE1 switch won't mark the packets. Thanks again!!
V/R,
Ian
Try this command on the ingress interface
mls qos trust dscp
Actually, that removed the service policy. I thought "mls qos trust dscp" was used when the dscp code was already marked by an switch closer to the packet source, and you just wanted to pass the current dscp code on (or remark it via a dscp-mutation map). Any other ideas? Thanks again for helping!
V/R,
Ian
Yes, it will. You want to preserve the dscp setting from the device, aren't you ?
Once the dscp value enters the switch (that occurs after the service-policy input) then you can change the dscp value as they egress the switch (you would use service-policy output).
No, actually, I'm running a "conditionally-trusted IP phone + PC" model. I do *not* trust my hosts to set their dscp settings correctly, just my Cisco phones.
Also, I tried applying the service-policy on the output (egress) side of my uplinks, and received the following warning:
Warning: Assigning a policy map to the output side of an interface not supported.
On page 330 of Tim Szigeti and Christina Hattingh's "End-to-End QoS Network Design" (Cisco Press, 2005), the authors state that there is an IOS bug where the counters do not increment, but that is supposedly only on the 3550 on IOS 12.1(19)EA1 and 12.1(20)EA1. I'm running a 3750 on 12.2(35)SE2. Maybe there is a similar bug?
Do you know of another way to check the dscp settings on packets coming in or out? The only way I know of is to put them through a traffic shaper (with "random dscp-based") and see what falls out of it....
V/R,
Ian
It appears that the bug in question *does* apply to the 3750 as well. We left the service-policy on since it apparently wasn't working, and we discovered that it was stripping the dscp EF marking off our VoIP phones. Our WAN routers were showing zero VoIP calls, even while I was actively making one....
V/R,
Ian
To check if dscp settings on packets, you can create an ACL match dscp and apply it to the interface.
I don't have a device at the moment to verify syntax but a 'permit ip any any ?' should help you complete the ACL.
Great idea! I didn't realize you can run an extended ACL against a DSCP value. Format is:
ip access-list extended QoStest
permit ip any any dscp ef
permit ip any any dscp af41
permit ip any any dscp default
permit ip any any
Apply that against the interface in question, and it does in fact track inbound DSCP settings. Thanks!
672
