11-29-2011 06:17 AM - edited 03-07-2019 03:39 AM
Pleae help
we have a class based qos scheme (see attached file) on our 4500 series access switches and we have a access 3560-48 switch runing IOS Version 12.2(44)SE3 my question is can I use the same QOS scheme for the 3560 switch?
Tanks,
Jack
11-29-2011 06:41 AM
The commands may not be exactly the same, but the IOS for 3560 supports class based Qos.
here is the config guide for Qos"
11-29-2011 07:04 AM
Reza,
will enabling auto QOS on the swith be just as good?
thanks,
Jack.
11-29-2011 07:18 AM
Jack,
Yes, for VoIP Qos parameters, Auto Qos with configure it for you automatically
Have a look at the command reference guide for the policy-map auto Qos will configure for you.
