QoS for access ports
Gents,
How to implement the following design. I would like to guaranty 5% of bandwith of uplink on access switch for each access port. If we don't have congestion, bandwith is not limited on access port.
How do it ?
Could you pls give the example of this QoS policy ?
My hardware is c2960, 24 10/100 access ports, 1Gb uplink. Distribution level is c3750G.
Thanks.
Re: QoS for access ports
Switch by default has only four output queues and we can only play around with that and in case of a Access-switch , AFAIK Qos of your requirement is not possible.
And in your 3750 switch , you can split your access-group to 4 groups and allocate diff bandwidth for them.
ref:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12225see/scg/swqos.htm
Hope this helps
regards
vanesh k
Can LLQ policy be used on c3750?
Or it can be only xRED?
You cannot use LLQ as you use in a router , but one of the four queue , I think queue3 can be made as a priority Queue .
Hope this helps
regards
vanesh k
126
