12-16-2013 09:23 AM - edited 03-07-2019 05:06 PM
We recently purchased some 4510s for some of our larger branch offices. Our Telecom department favors Avaya so we have a bunch of Avaya 9600 series IP phones. We were just assuming we'd use autoQoS but that is not an option on the Sup 7E. I'm trying to build a very basic MQC QoS config that only fixes the COS value from 6 to 5. I want to leave the default queueing alone. The Avaya phone tags as DSCP 46 and COS 6. Anyone have a working config they can share? I tried the following but it didn't seem to work, a packet capture still showed COS 6 coming from the port:
class-map match-any VoIP
match dscp ef
policy-map SET-COS
class VoIP
set cos 5
int gi1/1
service-policy input SET-COS
Rob
12-16-2013 09:55 AM
Rob
Where are you doing the packet capture in relation to int gi1/1 ?
Can you post full config of gi1/1 ?
What IOS version are you using on the 4500s ?
Jon
12-16-2013 10:52 AM
Hi Jon,
Thanks for your response. The full config for gi1/1 is:
interface GigabitEthernet1/1
switchport access vlan 100
switchport voice vlan 101
spanning-tree portfast
end
We did the packet capture using a Fluke Omniview attached to a span port set with dot1q encapsulation. The IOS version is cat4500e-universalk9.SPA.03.02.05.SG.150-2.SG5.bin. We're just trying to respect the DSCP 46 (EF) tag presented by the phones and pass it as COS 5 also.
Rob
12-16-2013 11:59 AM
Rob
Apologies for the delay but i had to read up on the new QOS on 4500s. I can't see what's wrong with your config. The only thing i found was this from the config guide -
Some of the documentation seems to suggest you can set CoS on ingress but the above is saying you can only set on outgoing traffic. The config guide cover the 6-E and 6-LE but i can't seem to find one for the 7L, unless it hasn't changed.
I'll keep searching but If all the traffic is going out a trunk link it may be worth trying to set the CoS value there instead of inbound, especially as you are not looking to do any queueing etc. on the switch.
Jon
